D90 Rebuild......
LandyAndy
Maxi Drive
Re: D90 Rebuild......
#26 Post by LandyAndy » Tue Dec 04, 2012 3:19 pm
discojonny wrote:What size is that tubing? 1 1/2" 1/8" wall?
looks great.
No, 1 7/8" x .120 wall DOM for all the main stress areas, HREW for the front wings.
Horn Blower
#27 Post by HeadDamage » Tue Dec 04, 2012 3:59 pm
What bender are you using?
LandyAndy
Maxi Drive
#28 Post by LandyAndy » Tue Dec 04, 2012 4:22 pm
HeadDamage wrote:What bender are you using?
JD2 Mk3 with a 6.5"CLR die & Bendtech Pro V6 for design.
#29 Post by ANDYD » Wed Dec 05, 2012 12:24 am
Its looking great Andy, thanks for sharing the build ... when do you expect to "launch" her?
LandyAndy
Maxi Drive
#30 Post by LandyAndy » Wed Dec 05, 2012 8:03 am
ANDYD wrote:Its looking great Andy, thanks for sharing the build ... when do you expect to "launch" her?
Prob not until the spring.... still allot of work to do on the fabrication and then all the wiring needs to be sorted out plus the engine is getting Megasquirt and that's a whole other mini-project :roll:
LandyAndy
Maxi Drive
#31 Post by LandyAndy » Sun Dec 09, 2012 8:51 pm
Bit more work done on the spare tire carrier...
Spare is held up nice & high, leaving access to the rear winch & tow hitch.
http://i946.photobucket.com/albums/ad30 ... C05526.jpg
Will mount a 3rd brake light into the middle of the carrier frame.
http://i946.photobucket.com/albums/ad30 ... C05527.jpg
Made it easy to load too, the darn thing is rather heavy to lift.... or I'm just getting old !
http://i946.photobucket.com/albums/ad30 ... C05528.jpg
Washed Up
#32 Post by Dave_F » Sun Dec 09, 2012 9:54 pm
Looking great.
The tire carrier in the load position could be used for a table...or a toilet...with a little modification :lol: :lol: :lol: :lol:
LandyAndy
Maxi Drive
#33 Post by LandyAndy » Sun Dec 09, 2012 11:28 pm
Dave_F wrote:or a toilet...with a little modification :lol: :lol: :lol: :lol:
Umm.... reminds me of the Top Gear bumper dumper :mi7:
skeena river rover
#34 Post by skeena river rover » Thu Dec 13, 2012 8:49 pm
I like it! Can't wait to see when it is finished!
e.prevost94
#35 Post by e.prevost94 » Thu Dec 13, 2012 9:07 pm
Looking great! Are you planning on making the rear "Defender Like" for lack of better words?
LandyAndy
Maxi Drive
#36 Post by LandyAndy » Thu Dec 13, 2012 9:53 pm
e.prevost94 wrote:Looking great! Are you planning on making the rear "Defender Like" for lack of better words?
The back will get some alum skins over the steel framework, not sure if I'll put a roll on the top of the sides or just follow the angles... still some more tubes to add to brace the back corners and then can draw up some diamond plate lockers.
LandyAndy
Maxi Drive
#37 Post by LandyAndy » Fri Feb 15, 2013 9:41 am
Bit more done.... mounted my ground anchor, started to get the front fenders on the wings & got a few Carling switches, just need to design a custom LHD dash now to put them in :roll:
http://i946.photobucket.com/albums/ad30 ... e4607c.jpg
http://i946.photobucket.com/albums/ad30 ... 8ed842.jpg
http://i946.photobucket.com/albums/ad30 ... b1e9b6.jpg
With the front & rear fenders on it's starting to look well chunky :D
http://i946.photobucket.com/albums/ad30 ... fcdfc6.jpg
LandyAndy
Maxi Drive
#38 Post by LandyAndy » Wed May 08, 2013 8:13 am
Got some more done, inbetween rebuilding a 4.6 for the D2 & getting ready for the NWOR in June.....
Hydro assist & harness mounts kits
http://i946.photobucket.com/albums/ad30 ... 3c65b3.jpg
http://i946.photobucket.com/albums/ad30 ... 82a9d3.jpg
http://i946.photobucket.com/albums/ad30 ... fee5e8.jpg
Rear shock & bump stop mounts made
http://i946.photobucket.com/albums/ad30 ... 99edcb.jpg
http://i946.photobucket.com/albums/ad30 ... 5b526a.jpg
Air temp sensor adaptor fitted to old AFM for the Megasquirt install
http://i946.photobucket.com/albums/ad30 ... 0facaa.jpg
New front lower shock mounts and bump stop mounts made
http://i946.photobucket.com/albums/ad30 ... 5a951c.jpg
http://i946.photobucket.com/albums/ad30 ... f52ec7.jpg
Next to finish the front upper shock mounts, panel tabs & brackets on the cage then it's all apart for final welding & paint. Then to design & build a custom LHD dash to incorporate the Vintage Air AC unit I've got :D
LandyAndy
Maxi Drive
#39 Post by LandyAndy » Thu May 09, 2013 7:23 am
Front shock mounts made, this is the drivers side... it's kinked to clear the alternator
http://i946.photobucket.com/albums/ad30 ... 1f10d3.jpg
Passenger side mounted up
http://i946.photobucket.com/albums/ad30 ... c2119d.jpg
Tops will be tied into the wing tubing with bolted tabs for extra bracing & easy wing removal
http://i946.photobucket.com/albums/ad30 ... 1c473d.jpg
LandyAndy
Maxi Drive
#40 Post by LandyAndy » Thu May 23, 2013 6:09 pm
Strange Rover
#41 Post by Strange Rover » Thu May 23, 2013 8:53 pm
This may be the coolest thing I have ever seen, and as an avionics technician I can't help but want a set of those switches for myself :bounce:
LandyAndy
Maxi Drive
#42 Post by LandyAndy » Sun May 26, 2013 11:01 pm
A bit of a side project here, assembling the Staz Works double bead lockers is a right royal PITA, so.... I made a stand to pull the two rim pieces together & then it's just a case of putting the bolts in around the edge & torqueing them up. So much easier when you can sit & work at a reasonable height with both hands free.
http://i946.photobucket.com/albums/ad30 ... 4b38d2.jpg
http://i946.photobucket.com/albums/ad30 ... 679188.jpg
http://i946.photobucket.com/albums/ad30 ... bbe99d.jpg
LandyAndy
Maxi Drive
#43 Post by LandyAndy » Sun Jun 16, 2013 11:25 am
A few more little details worked out... headlight mountings, rear quick release mudflaps & hi-lift jack secured. All these little bits take the longest :roll:
http://i946.photobucket.com/albums/ad30 ... fbf190.jpg
http://i946.photobucket.com/albums/ad30 ... d8c611.jpg
http://i946.photobucket.com/albums/ad30 ... 0db163.jpg
http://i946.photobucket.com/albums/ad30 ... 2a8cc4.jpg
franko
#44 Post by franko » Sun Jun 16, 2013 12:44 pm
Man she is looking great!
LandyAndy
Maxi Drive
#45 Post by LandyAndy » Tue Jun 18, 2013 7:26 am
Washed Up
#46 Post by Dave_F » Wed Jun 19, 2013 6:03 pm
Stellar work so far...looking like it will be quite the beast....Baja or Dakar? Need a navigator? :D
It must just be the angle but the tire looks huge...hows the rear visibility?
LandyAndy
Maxi Drive
#47 Post by LandyAndy » Wed Jun 19, 2013 6:10 pm
Dave_F wrote:Stellar work so far...looking like it will be quite the beast....Baja or Dakar? Need a navigator? :D
More like local power line cuts.....
Rear visibility.... forgot what that was driving the D2 with all the storage rack in the back..... I've got side mirrors :D
LandyAndy
Maxi Drive
#48 Post by LandyAndy » Tue Jul 16, 2013 7:38 am
Finished off the front wings & had the centre section of the cage blasted to remove the old powder coating, added some additional top corner tubes, last few triangulation tubes to be added to the front screen hoop next.
http://i946.photobucket.com/albums/ad30 ... f3107d.jpg
http://i946.photobucket.com/albums/ad30 ... 1bfbae.jpg
99Disco2
#49 Post by 99Disco2 » Fri Aug 16, 2013 9:46 pm
Very awesome project and very impressive fabrication skills.
I noticed you are going to be running Megasquirt system on your project and was wondering what are you running for a transmission?
I have been thinking of running MS on our 99 D2 but have still to figure out how to control the ZF4.
Chris
LandyAndy
Maxi Drive
#50 Post by LandyAndy » Sat Aug 17, 2013 11:16 am
99Disco2 wrote:Very awesome project and very impressive fabrication skills.
Chris
Thanks... am running a RaRo ZF4-HP22 so it's all manual shift. If you want to keep the HP24 the guys back in the UK use Compushift... http://www.hgmelectronics.com/products- ... mpushiftii
Search on the D44 board, think there were some threads on there about using & setting it up.
