Series One windscreen
Any tips on getting the windscreen glass replaced for an 86 Series One?
rayhyland
- Drip Dry
Re: Series One windscreen
I am going to need the same answer at some point.
I was thinking of just going to the glass place in town and getting them to cut a sheet of glass the right size and thickness, and then putting 3M clear film on both sides for safety.
Ray
Ray
I like the "for safety".
I'd like to get actual laminated glass at a minimum, and heated would be better.
rayhyland
- Drip Dry
Yeah, that's the right way to do it for sure, if you can find it let me know where.
My series ones both have plain glass in the existing windscreens, no laminate, no temper, no film, no nothin.
Ray
Ray
me too, with a couple of significant chips that leave me nervous.
LandyAndy
- Maxi Drive
Give a commercial (truck) glass shop a try, the one here in Revy will cut & engrave with the correct CMVSS logo laminated glass for me, for work.
good idea. I'll look some up tomorrow
island dormy
- Drag Link
Hi Guys
I am going to try this again my last post just vanished.
All you have to do is remove your old windscreen and take it with you as a pattern to any glass shop. They will cut you a new one using the correct windscreen glass (which they will have in stock). I did this a couple of years ago it cost me $25.00 for each side and they gave me the new thin rubber strip that goes against the inside of the glass under the thin aluminun strips that hold the glass. On the outside I used Dum Dum strips avaliable at lordco.
Bye for now Victor 1962 Dormnobile
You can get proper, legal... laminated windshield glass cut at any automotive glass shop.
TDLightweight
Try Garibaldi Glass or OnSet Glass.
Garilbaldi can make anything, and Dale at Onset was a guy that I used to call up when I needed windshield work done on film vehicles. Both companies are in Burnaby.
- Washed Up
When i had my series 3 i went to speedy in n.van and left them the old glass and presto...a couple of days later i could see again. Night vision was "night and day" difference! :lol:
