Hi All,
Can some one recommend a good diesel injector service shop in the mainland area? I need my 300tdi injectors serviced/calibrated.
Thanks.
Diesel injector service
ishapiro
- Apprentice
BOlson
- Three Wheeler
Re: Diesel injector service
New West fuel injection
Talk to Gord , he's very knowlegable with
all aspects of Diesel injection
N W Fuel Injection Service (1983) Ltd
www.nwfuel.ca
www.nwfuel.ca
ishapiro
- Apprentice
Hey thanks for that tip!!
Just talked to Gord he sounds very knowledgeable.
Hope they will be able to fix the issues.
bf900
- Muddy Tyres
Hey, did you end up taking your truck in to new west? Did they resolve the issue? Good shop?
ishapiro
- Apprentice
Yes, I did go there last Thursday. I worked with Gord and Morgan and they were very helpfull and friendly. My 300tdi EDC had a slight smoking problem when cold. It would smoke and misfire only at around 1500 RPM so I assumed it would be fuel injection related as everything else looks good. They cleaned and calibrated the injectors but that didn't solve the issue. Then Gord mentioned the valve clearance. I did the valves 15K when I first got the truck so would never suspect that. I got back home and on the weekend rechecked the clearance. It seems to have solved my problem (knock on wood) :-).
In any case I would highly recommend them as they are very professional and look well equipied to deal with LR unique stuff.
bf900
- Muddy Tyres
Great thank you for the update.
