When I read that list, it sounds like a shopping list for the Icon.What they need to do is create a Jeep JK killer. Build something better on and off road at the sameish price point... This would be a huge profit maker and boost the rest of the line.
Let me propose the vehicle. You tell me if every off road enthusiast will sell their Rubicon or not.... This is very realistic and could be easily done.
- Body on frame construction with modular design to allow wagon, soft top, cab chassis, pickup, crew cab configuration. All with quality built in roll over protection and a design that allow simple change from one configuration to another.
- Dana 44 front, 30 spline. Optional manual locker. 4 link, long arm. 10" travel shocks. Optional cab operated sway bar disconnect. Antidive and squat set stable with travel and near 100%. High roll axis. Throw some money is to quality variable rate, speed sensing shocks...
- Dana 44 rear SWB, 60 LWB (35 spline), full floating. Long arm 3 link. 10" travel shock. Optional cab operated sway bar disconnects on LWB. Optional air suspension.
- 4 liter V6 NA gasoline engine or 3.5 liter V6 diesel. 6 speed wide ratio gearbox with granny 1st. The one they are using now should be fine.
- Keep the LT230, but offer a 4:1 optional low range.
- 265/75R16 as standard size. 285/75R16 optional. Clearance for 35x12.5 built in as stock.
- Keep the tire outside width to 65", body to 60". No center seating.
- Pricing within 20% of Jeep.
- Galvanized spaceframe body structure with solid colour plastic panel the clip on and off.
They do not need to reinvent the wheel. They need to get rid of the "bad" aspects of the current vehicle and keep the good. You make a vehicle that causes the off road enthusiast community to drool and you have half a billion dollars of free advertising that boosts sales across the company line.
And that's where my questions start.
How is Icon able to produce vehicles with little to no consideration for safety such as side impact curtains, crush zones, and all the items that we're being told have to go into a modern vehicle to make it regulatory correct to put on the market? -- and in California to boot??
Could a similar thing be done with the Defender we're all familiar with, taking the good and adding the best aftermarket upgrades to make an exceptional vehicle?
Is there a market for it? How big of a corporation would you have to be to make an impact, or perhaps the question should be how small do you have to be to run under the radar of red tape, bureaucracy, testing, etc. that the other manufacturers have to go through?
Is it possible to build a better Defender, still styled on the classic lines, and meet the needs of both the public and the regulators?
