My Series 1 rebuild
- Washed Up
Log in or register
Doh! :roll:
Guess you have to register or Log in just to view your progress!
- Washed Up
davran
- Washed Up
Re: My Series 1 rebuild
Finally after almost 2 years I have a rolling chassis.
Let the re-assembly begin :D
- (106.51 KiB) Downloaded 7813 times
- (104.63 KiB) Downloaded 7813 times
- (112.17 KiB) Downloaded 7814 times
Crs
- Missing Link
:alien: :cheers:
- Washed Up
...more progress...
Drive-train back in...new brake lines 90% complete and installed
New bushes in sandblasted Pedals, ready for paint
All dash parts restored or rebuilt
Choke assembly rebuilt and painted
Pedal to Carb linkages blasted and painted
Block painted...easier to see the leaks :lol:
Next up is painting the bulkhead and ordering up the wiring
This is why I haven't been coming out on any runs :80inch:
After 3 years it's time to finish this.
- (117.88 KiB) Downloaded 7612 times
- (125.43 KiB) Downloaded 7613 times
- (87.96 KiB) Downloaded 7613 times
- Landy Man
Coming along nicely Dave.
Good to see you're not giving up.
Bill
Bill
- Washed Up
Now I am starting on the body...jumping ahead a bit...
Finally found a paint mix that is very, very close to RAF Blue which the truck was originally painted.
The first pic is that of the original color... This is the new and old paint side by side....Color tone looks a bit different between the two pics but that is just the flash.
Can you post the source and numbers of your RAF Blue?
- Washed Up
This was done at Lordco, through their PPG OMNI system.swamijake wrote:Can you post the source and numbers of your RAF Blue?
- Washed Up
Before and After
other than my dirty fingerprints....
- Washed Up
More series 1 porn.....trial body fitting to be sure everything is lining up...then take it all off again and install steering... finish wiring, plus bodywork, paint and a myriad of other little jobs...
- Washed Up
Update...
Finally got the loom 90% installed and just have a few "issues" to resolve but coming along slowly and surely. Who knows it might even be ready by Founders day.
I am probably less than a month from firing it up for the first time in 3 years. :lol:
Anyone have a straight Series 1 bumper kicking around ????.
- (168.24 KiB) Downloaded 6153 times
- (230.11 KiB) Downloaded 6153 times
- (234.8 KiB) Downloaded 6154 times
- Landy Man
Keep going Dave, you've put in a tremendous effort so far, glad to see one get back together.
Bill :wav:
Bill :wav:
rayhyland
- Drip Dry
Dave, time for an update...
- Washed Up
Ok Ray... :D
Well from this...to this! :D
Having a bear of a time bleeding and the brake system. Gone through 1 series 1, and two CB series 2 type with an adapter plate.
Going to try a CV type as these are easier to bleed. If that doesn't work I will resleeve the original with a stainless insert.
All lights now wired up and working except rear brakes and flashers...should be road legal shortly.
Also made up a replacement vin plate complete with stamped vin.
Looking good!
Rambler
- Over Inflated
Looking very smart. Is that the RAF grey blue colour?
- Washed Up
Yup!Rambler wrote:Looking very smart. Is that the RAF grey blue colour?
Rambler
- Over Inflated
Great, thanks!
