Diesel swap OM617 into a Disco.
franko
Well i don't come on here much,but I have been lurking around.
I posted my build on our local forum island4x4, but I thought I should post it so that the rover community can see what i am up to.
Maybe I'll be ready for the 2nd trip on the Canol trail, that would be fun but we shall see.
Anyway, this idea came about because the wife wanted a diesel SUV for camping and what not. But not a RHD import. So the search began for a Disco,I was lucky enough to find one in Delta for under a grand and in pretty good shape , besides the leaky sunroof.
Okay so have the truck now the search was on for the motor, was able to buy a running mercedes with the OM617 diesel. Ran great drove for a week or so before pulling the motor, got the whole car for really cheap so that was a bonus.
Okay enough chit chat on with the pics.
The truck in the shop.
http://i302.photobucket.com/albums/nn87 ... 248JPG.jpg
http://i302.photobucket.com/albums/nn87 ... 263JPG.jpg
Gas pot pulled and out.
http://i302.photobucket.com/albums/nn87 ... 270JPG.jpg
And the old beauty herself.
http://i302.photobucket.com/albums/nn87 ... 271JPG.jpg
http://i302.photobucket.com/albums/nn87 ... 272JPG.jpg
http://i302.photobucket.com/albums/nn87 ... 284JPG.jpg
Not a bad way to pull a motor .
http://i302.photobucket.com/albums/nn87 ... 276JPG.jpg
All cleaned up.
http://i302.photobucket.com/albums/nn87 ... 285JPG.jpg
http://i302.photobucket.com/albums/nn87 ... 286JPG.jpg
Disco engine bay all washed and cleaned.
http://i302.photobucket.com/albums/nn87 ... 287JPG.jpg
More pics to come later on.
Also I must give full props to Chester for taking on this project with me and doing most of the work.
http://www.carlislefabrication.com/
The truck is in his shop and he is currently working on it .
Thats all for now.
All cleaned up.
Thats all for now.
PaulC
Engine swap
Looks like you are well on your way with the engine swap, it will be all the little things at the end that will give you the headaches!
We apprieciate you keeping a running log / photos of your progress, and look forward to seeing the "beast" come alive!
The members on this forum have done lots of diesel conversions, so if you have any questions then throw them out there!
good luck with your build,
PS. I gotta get one of those cool engine lifts that you have there! :D
These guys talk about developing a dry sump kit for the OM617 - might be worth a call.
http://www.4x4labs.com/
rezdiver
- Master Cylinder
franko
Well I had to order a bell-housing adapter from a guy on the East coast of the States Robert Davis. Some of you may have heard of him as he has been working with Series Land Rovers for a long time . And just so happens to be putting a OM617 into his Range Rover. So he was able to help me out and ship out his adapter plate , but it did cost me a few pennies.
All this to say that Chester still have to fab up a torque converter adapter. I have to say that he did a great job and it turned out wicked.
http://i302.photobucket.com/albums/nn87 ... 400JPG.jpg
http://i302.photobucket.com/albums/nn87 ... 401JPG.jpg
Below you can see the adapter plate that I had to order from Robert.
http://i302.photobucket.com/albums/nn87 ... 402JPG.jpg
And this is the adapter that Chester made.
http://i302.photobucket.com/albums/nn87 ... 431JPG.jpg
http://i302.photobucket.com/albums/nn87 ... 432JPG.jpg
http://i302.photobucket.com/albums/nn87 ... 433JPG.jpg
Lots more to go later.
franko
Well work is getting done for sure, but we are running into a bit of a hiccup. Something that we knew was going to be the biggest issue. THE OIL PAN!
Anyway engine is going in for motor mount mock up.
http://i302.photobucket.com/albums/nn87 ... 010498.jpg
http://i302.photobucket.com/albums/nn87 ... 010511.jpg
http://i302.photobucket.com/albums/nn87 ... 010502.jpg
http://i302.photobucket.com/albums/nn87 ... 010504.jpg
http://i302.photobucket.com/albums/nn87 ... 010506.jpg
You can see in the picture below how much it has to lean over. http://i302.photobucket.com/albums/nn87 ... 010515.jpg
http://i302.photobucket.com/albums/nn87 ... 010516.jpg
And this is the oil pan that is giving us all the grief
http://i302.photobucket.com/albums/nn87 ... 010499.jpg
http://i302.photobucket.com/albums/nn87 ... 010523.jpg
http://i302.photobucket.com/albums/nn87 ... 010521.jpg
seapotato
have you seen this?
couple interesting oil pans
http://forum.ih8mud.com/diesel-tech-24- ... -fj55.html
franko
Well I guess its about time for an update. We are back on track after having to rotate the adapter so that now the engine sits upright and has better clearance under the oil pan.
Had to cut the bell housing a bit to clear the starter.
http://i302.photobucket.com/albums/nn87 ... G_7963.jpg
http://i302.photobucket.com/albums/nn87 ... G_7964.jpg
http://i302.photobucket.com/albums/nn87 ... G_7965.jpg
http://i302.photobucket.com/albums/nn87 ... G_7966.jpg
Side view and the hood still closes with it upright.
http://i302.photobucket.com/albums/nn87 ... G_7977.jpg
http://i302.photobucket.com/albums/nn87 ... G_7976.jpg
http://i302.photobucket.com/albums/nn87 ... G_7975.jpg
franko
http://i302.photobucket.com/albums/nn87 ... G_7981.jpg
http://i302.photobucket.com/albums/nn87 ... G_7980.jpg
http://i302.photobucket.com/albums/nn87 ... G_7979.jpg
http://i302.photobucket.com/albums/nn87 ... G_7978.jpg
Most everthing is clearing alright, might need to trim the valve cover or the cowl so that the valve cover can come on and off.
franko
What, are you guys all snoozing? Must be a bunch of old farts around here.
No comments at all.
Anyway got most of the motor mounts down.
http://i302.photobucket.com/albums/nn87 ... G_8068.jpg
http://i302.photobucket.com/albums/nn87 ... G_8073.jpg
http://i302.photobucket.com/albums/nn87 ... G_8070.jpg
http://i302.photobucket.com/albums/nn87 ... G_8069.jpg
And you can see in the picture below one of the cuts to the oil pan to clear the steering box.
http://i302.photobucket.com/albums/nn87 ... G_8074.jpg
No comments at all.
PaulC
franko
Dreslerdisco
Go frank Go!!!!.
dude
your truck is rad. I am so glad we have time to disco soon. you into party? maybe some logging roads? some camping.
get it done!
get it done!
franko
Thanks Scott, you will have to come out with me on its first test drive.
Well its starting to come together a lot faster these days.
Got the pan all modified so now I have enough clearance for the diff and all.
http://i302.photobucket.com/albums/nn87 ... G_8087.jpg
http://i302.photobucket.com/albums/nn87 ... G_8088.jpg
Closed up the gap on the bell housing, welded a chuck on to it.
http://i302.photobucket.com/albums/nn87 ... G_8090.jpg
http://i302.photobucket.com/albums/nn87 ... G_8091.jpg
And here is what the pan looks like.
http://i302.photobucket.com/albums/nn87 ... G_8094.jpg
http://i302.photobucket.com/albums/nn87 ... G_8098.jpg
Dreslerdisco
Weirdedst thing happened.
So I have to put a new gasket on my oil pan... leaks a bit. I was poking around down there and I brushed my hand against something and all of the sudden I was doused with about three or four cups of water... I was soaked by my truck. I am thinking it was some kind of air conditioning drain nipple... so I checked for another one on the other side... soaked. At least I didn't have my mouth open.
romayama
- Grease Monkey
Discovery Diesel Isuzu 4JB1T conversion
Hello,
I've always been curious about those MB engines fit into Discos. Did you manage to get it driving? How is the power of it?
Here are some pictures of my on-going Isuzu 2.8 turbo diesel conversion:
http://design-engine.ca
My engine is running poor so I'm going to rebuild it soon.
Regards,
Roman
Regards,
Roman
