Custom hitch/bumper/cross member
Flyingcatfive
I'm just looking for any cost effective suggestions here for a class 3 hitch for the 110. Ive got to cut out some rust and build a hitch / bumper combo. I thought of picking up a princess auto hitch and modifying it as the steel in their products is usually cheaper than raw materials. (must be cheap mix of fillers?)
Anyone do this already and have a photo of what they've done that works or other ideas?
Thanks!
Thanks!
seapotato
I did it like this...
I think it was 2" x 5" rect tubing. I notched in a piece of receiver tube for tow hitch, so it didn't hang down to far, and sleeved some holes for a pintle hitch above it.
you could cut the angles and such to make it more closely resemble the factory crossmember, and recess it under the body for a more stock look as well
it was pretty easy to make this way.
http://i80.photobucket.com/albums/j171/ ... 009010.jpg
Flyingcatfive
seapotato
I'll try and remember to take a picture tonight. You can get replacement cross members cheap in the UK. if you can figure out how to ship cheap, it would be simple. if not, and you can build stuff do what seapotato did.
http://www.lrseries.com/shop/product/li ... ber&page=1
http://www.lrseries.com/shop/product/li ... sis&page=1
Here is my hitch. Obviously if you are making a crossmember you have a lot of latitude.
http://i2.photobucket.com/albums/y45/Re ... /hitch.jpg
rezdiver
- Master Cylinder
just another idea, you could get one of these combination pintle and 2 inch ball hitches to make it simple. i got one from princess auto for 125 dollars to replace my existing pintle only hitch, made in the USA 5ton rating.
http://www.etrailerparts.com.au/2450.html
seapotato
Flyingcatfive
