Def 90 rear hub oil seals effected by heat?
dchsw
Both hub oil seals on my D90 started weeping sometime in the last week or so. Any chance they are adversley effected by the hot weather? It just strikes me a bit odd that they both decided to do it at the same time.
Also, anywhere I can get replacement seals localy? I'm not exactly sure which type of axle it is, but I'm assuming the earlier single seal type until I can get the hubs apart and have a look. Replacements for this type are $3.50 each plus P+P from the UK.
Thanks! David.
Thanks! David.
dchsw
bclandrover
dchsw
Don, Dave, JD,
Well, checked the breather and it looks ok, but taking it off could well have unclogged it. This an MOD vehicle, so has breather extensions which could be blocked, haven't had chance to blow some air through them yet.
I've not had time to take the hubs apart either, but have taken the wheels and brake drums off for a quick look-see. Interesting thing is that the hub caps where both half full of oil but after taking them off and cleaning up the end of the axle shaft and the hub driving member (cast bit with five holes in it) there are no noticable leaks.
The truck has been stood for a couple of hours now and there's not a drop of oil on the floor. I'm going to leave it with the wheels off in my shop for a week or so whilst I'm away on buisness and see what happens.
BTW - the axle turns out to be of the later type with both inner and outer seals. Bizarely I have a dozen inner seals in my box 'o bits, but no outers - how the heck did that happen! I'm going to be in the UK from Thursday so I'll pick some up whilst I'm there.
I'll keep you posted. David.
seapotato
