About to buy my first Rover
yuppa
Could use some advice!
Of course I want an old one, however the wife is expecting and she wants something newer (baby friendly).
Given my limited budget, I've narrowed the field down to a couple..
#1 - 1988 range rover, tons of work done, looks great, body lift, big tires ect. pricey for its age but it looks well taken care of.
#2 1995 land rover disco. very underpriced compared to what I see on craigslist and such, its from a used car dealer and Im not sure I trust them, also I see a lot of maintence issues with disco's and for the price Im afriad it might be a money sink. however its a lot newer and the wife likes the look.
I realise its going to be a lifetime before I can afford my dream car (defender!) and i hope to pick up an older rover in a year or two.
I would like any suggestions/reviews/comparisons or general rover advice.
Roverworks
- Greasy Fingers
I've had two 88 range rovers and enjoyed them both. I would like to echo the words of wisdom from the previous posters... do a thourough mechanical inspection but I also suggest that you educate yourself as well. Rangerovers.net is a good place to start and they provide some excellent information about these great old trucks.
Good luck!
Good luck!
yuppa
great
looking at a 95 disco later today
now, where can you guys recommend i take it to get inspected?
I live in new westminster.
Does anyone know of a land rover mechanic in new west/burnaby/coquitlam?
I called the downtown rover dealership and they quoted me 395 bux to get it inspected.. thats crazy
I would like to take it to rover works but north van is out of my way considering I don't actually have a vehicle yet
yuppa
PaavScan
yuppa
I heard keepign it on "3" instead of "D" for city driving improves fuel economy? can anyone relate?
so irregardless to that.. heres what i've notices as a new land rover owner..
Unfortunately I didn't get a user manual OR a haynes manual with the vehicle.. ebaying a haynes, but cant find an original user manual anywhere..
so i have lots of "dumb" questions
whats the SRE light by the speedo mean
how can I tell if im in low or high? -4x4 stick appears to be in nuetral.. if i shift it left, the 4x4 light lights up on dash, I assume that means im locking the differential? when its in nueutral, and i shift up (to low) or down (to high - according to diagram) .. I just get a beeeeeeee sound...
so i really dont know how that 4x4 stick works..
also I get the occasinal "whif" of a bad smell.. like rubber or plastic burning sometimes.. my friend says its the smell of curry (last owner is from overseas) when I open the engine I dont smell it at all..
humm if not for that strange smell sometimes, I'd be like.. wow this is the best vehicle evar
yuppa
96whitedisco
96whitedisco
yuppa
PaulC
Your Permanent 4 Wheel Drive System’s transfer case has 4 drive positions. Hi or Low Range Unlocked (Center Differential Unlocked), these are the 2 positions used while driving on dry or wet hard surfaces. Yes you can use Low Range (Unlocked) on dry surfaces.…pretty unique feature.
And Hi or Low Range Locked (Center Differential Locked), these 2 positions used for low grip surfaces.
When the Transfer Case is in the “Locked” position (HI or Low Range) you should see a orange driveline light on the instrument cluster, above the speedometer.
When the Transfer Case lever is pushed to the right the Centre Differential is Unlocked. Pull the T-Case lever to the left and you Lock the Centre Differential.
And of course HI Range is the Lower Position (to the Rear of the vehicle) and Low Range is selected by pushing the lever (with Transmission in Neutral of course) towards the front of the vehicle.
Hope this clears it right up for ya. :shock:
