Rover v8 exhaust manifolds
Posted: Thu Oct 18, 2018 8:56 am
by dixono
Does a 4.6 p38 header bolt onto a 4.2 rrc block? Same bolt pattern or no?
Re: Rover v8 exhaust manifolds
Posted: Thu Oct 18, 2018 7:06 pm
by Tony4921
The 3.5, 3.9, 4.0, 4.2 and 4.6 have interchangeable heads. The only difference is that the early ones had 3 rows of head bolts as opposed to the later 2 row. Even still, the intake and exhaust ports are unchanged. I tried to put a set of THOR 4.6 headers (1999-2002) on a 4.0 D2, they will bolt on the head, but hit the firewall. So, yes they will bolt onto your 4.2L heads, but not sure about firewall clearance on a RRC.
Posted: Fri Oct 19, 2018 12:17 pm
by dixono
I see. On My 4.2 exhaust manifold the down pipe is between the two middle pipes where as the p38 header down pipe comes down around the back pipe closer to the firewall. I’ll have to look under my hood and investigate
