2 inch lifts for Discovery 2
Posted: Tue Jun 19, 2018 8:20 pm
by Abouttime
Hi,
I'm new to Rover-Landers and for that matter Land Rovers, but I have always wanted one. Hence the Username. I come from a Land Cruiser, Patrol background. So my question is this, I want to run 31s on my Rover instead of the stock 29s and I figure a 2 inch suspension lift will do it without altering the angles of the propshafts to the diffs and T-case too much. Does anyone have any suggestions or advice on doing this with a Discovery? I don't want to modify it too muchas the truck is mint with a full service history just want to run slightly larger tires.
Re: 2 inch lifts for Discovery 2
Posted: Tue Jun 19, 2018 9:27 pm
by Rob
D2s are great trucks IMHO. I had one for years and was very pleased with it. I went to 245/75r16s without any suspension modifications and had no rubbing problems on the rear and only a slight steering rub on full turn.
https://farm3.staticflickr.com/2470/3843180882_892c8cf5f4.jpgcanon pics april 2009 044 by
green_rover_guy, on Flickr
There are many tires to choose from in that size and they are about a 30.5 tire. Here is a informative thread on tire size options
http://www.landroversonly.com/forums/f4 ... tion-6885/
Posted: Wed Jun 20, 2018 6:00 am
by Abouttime
Thanks for the information and advice. The truck came with 18s so from the available options of listed tires I should be looking at obtaining a set of 16 inch rims first before hand as then there are for more tires available. One more question. Will the rims off a Disco 1 fit a Discovery 2?
Thanks again.
Posted: Wed Jun 20, 2018 7:18 am
by bsa_m21
Re: Will the rims off a Disco 1 fit a Discovery 2?
No. :roll:
M.
Posted: Wed Jun 20, 2018 11:07 am
by acg
This is my Disco with 275/65R18 (32") on the 2" lift:
http://roverlanders.bc.ca/gallery/view_ ... d=DSC_7805
(Thanks to Dave V for use of this pic)
This is the largest tire which I could run without encountering major rubbing issues on the front wheel. 2" lift is the most you can probably go without having to deal with changing brake lines, adversely affecting driveline geometry, etc.
Posted: Wed Jun 20, 2018 11:43 am
A regular spring lift does not change tire clearance since the axle travel is not changed, only the ride height. 32s fit on a Disco 2 stock.
