2000 RangeRover HSE SOLD
Posted: Sun May 20, 2018 11:22 am
by Colin
I am selling my gold 2000 RangeRover in North Vancouver.
Here is the good:
Atlantic British Bullbar
Yakima roof rack bars
Shop manual
Arronet springs with extended lift
brand new right rear rotor and caliper (last month)
Newish left rear rotor and caliper (about 1 year)
General Grabber AT2 with about 50% tread
Now the Ok
I rebuilt the air suspension valve block, but the left front valve leaks overnight, didn't fix it, because my wife likes it down to get in. Comes up fine. I have the whole old unit as a spare, with valve block, compressor and control unit. Also have a spare EAS ECU and two rear Britpart height sensors that are not yet installed.
Now the bad
The tranny just lost 3/4 gear. The truck still is drivable, you have to start in first and work your way up and reverse works, the shop checked, the problem is inside the Tranny and we dropped the pan, no bits and pieces found.
The exhaust system is almost gone and will need replacing
The headliner is starting to detach behind the rear seats, could be halted by putting trim plugs in.
The EAS system is a bit wonky, been slowly hunting down the issue, the next part was to change all of the height sensors. I have the RSW software, I can't give you the software, but would include the plug in the sale
Price is very negotiable
Re: 2000 RangeRover HSE for sale
Posted: Sun Jul 15, 2018 7:50 pm
by Colin
Sold to another Roverlander
