300tdi drop in?
Low-Range
Junior Craftsman
300tdi drop in?
#1 Post by Low-Range » Wed Aug 24, 2016 10:36 pm
My defender 2.5 diesel broke. Will a 300tdi mate with the lt77 transmission? Other mods required? Motor mounts etc?
Re: 300tdi drop in?
#2 Post by swamijake » Sun Aug 28, 2016 4:16 pm
i have a great 2.5 nad you can buy.
I swapped to the 300tdi. its not a direct swap, but it is doable. best way to do it is get it with the r380 and all the extra bits you need. (floor pan, radiator, mounts, etc)
The wiring is easy as long as you get a non computer controlled engine.
StuartL
Horn Blower
Re: 300tdi drop in?
#3 Post by StuartL » Wed Aug 31, 2016 11:27 pm
Go with a 200TDi it is a drop-in.
Low-Range
Junior Craftsman
Re: 300tdi drop in?
#4 Post by Low-Range » Mon Feb 19, 2018 2:44 pm
300tdi easy swap. Suggest a Steve Parker kit. I used one and it worked quite well. It includes all you need with instructions. Also got the complete exhaust system. Wasn't cheap but if you cant fabricate and or don't have the time and energy the lit works well.
