Brackets on Series bulkhead - what are they for?
Posted: Mon Jan 05, 2015 4:48 pm
For a while I have wondered what the brackets near the top on the engine side of the bulkhead are for. On both of the 2 Land Rovers which I've had on the road ('74 SIII 88 and '71 SIIA 88) they have been present but not attached to anything.
I did a bunch of searching of images and found almost all pictures of Series engine compartments show them, but not attached to anything. Only a couple of pictures I've seen, show the passenger side (I've seen an example of both left and right hand drive) bracket with what seems to be a rod linking to (possibly) the brace that supports the steering box on the driver's side, but only on the passenger side.
Mostly as a matter of curiosity at this point, anyone out there know definitively what the purposed of these brackets is? I should add that they are mounted at different angles to the bulkhead, so not exactly mirroring each other but pretty close.
