Rover 4.6 rebuild
Posted: Sat Dec 13, 2014 8:49 am
I have bought another discovery 2 rover 4.6 that the oil pump failed.
The shop I bought it from attempted to repair the engine and install 0.01 oversized bearings but could not get the crank to turn.
After inspection I found they had the crank polished and not turned to 0.01 oversized. I measured the crank and it is 0.005 undersized from spec. So I have two choices. Use standard bearings and hope for the best on oil pressure. or turn the crank another 0.005.
Anyone have any experience on 4.6 or 4.0 rebuilds? Can I go out of spec by 0.005 and still be okay?
