Question re. bent frame spring hangers
LR01011000
Junior Craftsman
#1 Post by LR01011000 » Tue Oct 28, 2014 9:18 pm
Hi everyone - I have a new galvanized frame which I am about to start bolting stuff to. In shipping, the front spring hanger tabs were bent, and I need to straighten them. Before I start beating or reefing on them, I was hoping to get input and advice on whether there is anything to avoid or any recommended way to do this (eg. heating before bending?)?
Thanks !
DrRangelove
Hot Manifold
Re: Question re. bent frame spring hangers
#2 Post by DrRangelove » Tue Oct 28, 2014 10:40 pm
Had to straighten mine out to get my new parabolics to fit... just used a little heat with a propane plumbers torch and bent back into place with a pinch bar surprisingly easily. No wockin' furries!
#3 Post by red90 » Wed Oct 29, 2014 7:27 am
If you heat enough to affect the steel, you will ruin the galvanizing. Damaging the galvanizing would be my largest concern.
LR01011000
Junior Craftsman
#4 Post by LR01011000 » Wed Oct 29, 2014 11:21 pm
Tried the cold bending using a very large crescent wrench and some angle iron to provide complete grip on the hangers, got them back to pretty close to where I think they should be - on the weekend, I will hang the springs on, rear shackles first and then fine tune to align the springs with the frame.
The galvanizing seems to have survived the bends intact, but I will spray with the cold galvanizing coating from Rona if I suspect any damage to the finish when I'm done with the finicking....
....thanks for the help guys!
