Series III 88" diffs
mgbgtn
#1 Post by mgbgtn » Wed Aug 20, 2014 11:20 am
The rear end on my 88 has a lot of free play and I was wondering if I could replace the center section with a spare front end center section I have as a spare?
Re: Series III 88" diffs
#2 Post by Greg S » Wed Aug 20, 2014 11:24 am
If you mean the "third member" as in the differential unit. Yes, they are the same. Slop can be axle wear between the splines on the axle and dif. side gears (spider gears) and also on the splines at the drive flange at the wheel hub. The backlash of the crown and pinion gear can also be needing adjustment or simply put in your spare unit.
mgbgtn
#3 Post by mgbgtn » Wed Aug 20, 2014 11:28 am
Yes, I was referring to the third member. Thanks for the information.
