Rear seal.
Posted: Tue Jun 10, 2014 7:29 am
by Gromit Dog
Hey there. when i checked and adjusted my brakes I found the right rear drum wet (inside) with gear oil. I cleaned it but need to replace the seal/gasket... I don't have a manual or parts book so I'm not sure what there is to leak there. Anyone able to tell me what to order? i don't want to take it apart again until I'm ready to fix it.
Bill
Re: Rear seal.
Posted: Tue Jun 10, 2014 7:56 am
by Rob
Hi Bill
I refer to the PDF scanned manuals available at the following address quite often for rover references http://www.landroverweb.com/landrover/p ... r-manuals/
Cheers, Rob
Re: Rear seal.
Posted: Tue Jun 10, 2014 8:11 am
Gear oil from the hub seal, most likely RTC3510. Try to make sure you get quality ones and make sure the seal running surface is good. The design is the same as any traditional full floating hub. Or it could be the flange to the axle.
Here is a list for alternative part numbers for seals and such if you want to find locally: http://www.expeditionlandrover.info/LRpartNumbers.htm
You can download the manuals, but I would suggest also buying the factory manuals and carry them in the truck. http://www.paddockspares.com/parts-and- ... nuals.html
Re: Rear seal.
Posted: Tue Jun 10, 2014 10:57 am
by island dormy
Hi Grommet dog
If you are not already a member of the series 2 club you should be. It is the place to go for any series 2 or 2a Rover owner. Any problem you have will be answered fast and usuaully with photos. Great club with a really good search engine. You need to sign up to ask questions and see all the photos that come up. It is free to sign up to post on the forum.
Rover landers is great we have a lot of very smart fellows on here but for a series 2 owner you can not beat the knowledge some of the guys in the series 2 club have.
Victor 1962 Dormobile
Re: Rear seal.
Posted: Tue Jun 10, 2014 1:12 pm
by Batrover
It could also be your rear brake cylinder, I had the same problem on my 109 and it ended up being the rubber seal leaking over time. Sometimes grit gets into the piston area and creates a leak. If your pads are wet also you will have to change them out.
Thanks for the reminder about Rocky mountain for my lift. I always forget about them being in Van.
Re: Rear seal.
Posted: Tue Jun 10, 2014 5:00 pm
by DrRangelove
Most likely the hub oil seal. I have mine pulled apart if u want to check it out next time you're in parksville.
When you do the job check your breathers at the same time. If theyre blocked the pressure will cause seals to go...
Re: Rear seal.
Posted: Thu Jun 12, 2014 5:57 am
by Gromit Dog
Thanks for the help. I nee to sort it quick. I'm pretty sure it's gear oil as it doesn't feel like brake fluid and there is no indication of leaks at the cyl. as for contamination... I have a "trade secret" to fix that. It's not recommended but it CAN work. taught me by an old Dutch mechanic years ago.
If I must though, I'll replace shoes.
