Locking mechanism in D2 transfer case
Posted: Sat May 25, 2013 3:57 pm
by davran
I've read that D2s lost their auto-trans coolers and locking mechanism in the transfer case in late '00. Our previous '01 D2 -- that got written off when Cyndi was hit head on -- didn't have either (it was an 01/01 build). The replacement D2 is an 11/00 build. I confirmed a while ago that it has the trans cooler, but today I decided to see if it still had the transfer case lock, and I was very pleased to find it did. I activated it with a 10mm wrench, and the dash light came on.
I found this link on how to install the mechanism:
http://www.discovery2.co.uk/diff_lock.html
No one wants to buy the D2 (happily for me, not as much for the dog), so now to source a lever mechanism.
Re: Locking mechanism in D2 transfer case
Posted: Sat May 25, 2013 6:02 pm
by LandyAndy
You can either try & find a wrecked '04, mess about installing the manual linkage from a D1 or just buy the Ashcroft parts from Justin at Lucky8.... http://www.lucky8llc.com/Products.aspx?ProductID=2185
Also, while you have the centre console & auto shifter out, remove the shift interlock solenoid from the shift mechanism. You can get the transmission into neutral then if you ever need to be winched out with a dead vehicle :wink:
Posted: Sat May 25, 2013 8:08 pm
by davran
Thanks for the tip about the shift-interlock solenoid.
Posted: Sun May 26, 2013 12:04 am
by Rob
Hi Dave
I've been researching the same topic and I found the following link is a good source of information about the steps for installing a D1 CDL shifter into a D2.
Cheers, Rob
http://www.google.ca/url?sa=t&rct=j&q=& ... 5395,d.cGE
Posted: Sun May 26, 2013 6:42 pm
by davran
Had anyone ever used the CDL lever from Great Basin Rovers?
http://gbrutah.com/cs_drivetrain_transf ... e.html#cdl
