Axle Breather Fittings
DBrands
Wing Nut
#1 Post by DBrands » Sun Feb 17, 2013 10:54 am
The breather on my rear axle has been damaged and I would like to replace it. Does anyone know of a local source for 1/8" bsp fittings to replace it with?
I see that I can order a whole push fit kit from the UK, but really only need the one fitting. Should I try a local pneumatic supply?
Thanks for any insight.
David
Re: Axle Breather Fittings
#2 Post by swamijake » Sun Feb 17, 2013 11:45 am
bigger home depots, can tire doesnt have much, wolseley plumbing, alder auto
1/8 bsp is fairly common.
DBrands
Wing Nut
#3 Post by DBrands » Sun Feb 17, 2013 2:25 pm
DBrands wrote:The breather on my rear axle has been damaged and I would like to replace it. Does anyone know of a local source for 1/8" bsp fittings to replace it with?
David
Okay, so it looks like I have found a couple possible options after a bit of internet searching.
Pirtek Fluid Systems on Annacis Island and Precision Bearing in Abbotsford both appear to stock suitable fittings.
#4 Post by red90 » Sun Feb 17, 2013 5:02 pm
NPT and BSP are almost the same in the 1/8" size. You could just run a 1/8" NPT tap in to clean the threads and use a more common fitting.
#5 Post by mepham55 » Sun Feb 17, 2013 7:28 pm
I bought my axle breathes on eBay. Just search for 1/8 BSP air brush fittings with a 6mm push fitting. I think I paid $5 shipped for 3.
#6 Post by ANDYD » Sun Feb 17, 2013 8:02 pm
Maybe a good time to install breather tubing up high in the engine bay if you haven't already done that....
