Adjustable Caster Bushings
Posted: Tue Jun 21, 2011 5:36 am
by jeepingpw
Has anyone tried Adjustable Caster Bushings on their Disco front arms?
Posted: Wed Jun 22, 2011 11:03 am
by discojonny
I installed them on my 95 after driving for a while with my lift. A huge difference on the highway much more stable and tracks great, I can drive with one hand again.
Posted: Tue Jul 05, 2011 8:04 pm
by jeepingpw
How did you install?
They are round with an off set bushing.
Are they keyed?
How do they stay in position?
Posted: Wed Jul 06, 2011 8:10 am
by discojonny
they come with instructions for installing. They are a press fit into the arm no key or anything else, they went together fine, I was a little concerned but the install was fairly easy.
Posted: Wed Jul 06, 2011 8:14 am
What brand did you buy? How much $$?
Kevin, if you're bringing in a set, I could use a set too, also Josh in Salmon Arm is looking for the same.
Posted: Fri Jul 08, 2011 4:19 pm
by jeepingpw
Still trying to find some at a resonable price.
Most are about GBP 89.00
Just read this....
http://forum.landrovernet.com/showthrea ... ion-bushes
Posted: Mon Jul 25, 2011 9:13 pm
by jeepingpw
Heres the best prices I have found, less shipping.
I have found Fed Ex to be the cheapest & here in 4 days!
Just had a package sent for GBP 60.00
$96.00 CDN
(4 coil springs, 2 cap & rotors, drive shaft spacer, Fr & Rr spring retainers w/bolts, Fr diff gaurd. Took 2 of us to lift box off truck!)
Bearmach GBP 70.00,
$112.00 CDN
http://img.photobucket.com/albums/v493/ ... armach.jpg
Terrafirma GBP 60.00,
$96.00 CDN
http://img.photobucket.com/albums/v493/ ... afirma.jpg
Front radius arms for 2" - 3" lift, no bushings
GBP 195.00 ,
$312.00 CDN
http://img.photobucket.com/albums/v493/ ... /front.jpg
Rear Arms for 2" - 3" lift, no bushings
GBP 110.00,
$176.00 CDN
http://img.photobucket.com/albums/v493/ ... DA5510.jpg
Rovers North prices
Caster Bushings (look same as Bearmach) $130.00 USD
Front Radius Arms (plated) $500.00 USD
Posted: Wed Aug 10, 2011 8:46 pm
by jeepingpw
Just put in a 50mm coil lift in & no vibration & wheel pulls back to center.
Do I really need new bushings?
I will get the caster checked to see the degrees
