series 5 door body on a 110
dan
What would be involved in fitting a series 5 door body( just from the rear bulk head) to a 1986 110 3 door? Will the 5 door body fit in nicely? Or are there big issues? How different are the series body from the 110?
I've seen similar done, for example Rick in Salmon Arm has a 109 5 door built on a stretched Discovery frame. In all cases it's gonna require some modification to make it work as the attachment points and outriggers are quite different.
Might be worth finding a copy of the 4x4 is born video series before you start as that's about making a 100 inch hybrid, but much of the work will be similar.
Doc Tari
