Leaking coolant, costly repair estimate $
Posted: Sun Aug 15, 2010 1:22 am
Brought my Landy into dealership to find the cause of the TC ABS lights to remain on, as well as slow coolant leak, thinking it would be a 'small potatoes' quick fix. I wish I knew about these LR forums sooner!
Was given bad news that I apparently need another new radiator (which was replaced 8 months ago by an independent mechanic), head gaskets, repair to an oil leak.. after they performed a pressure test (?) Majority of coolant is leaking from rad.
I've been told it should all be done together.. but does anyone have any insight about what should be tackled first/immediately?? Coolant has been leaking slowly..and engine overheated once this summer.
Looking for a reputable local LR mechanic in the Lower Mainland :angel11: Not going back to my last mechanic for obvious reasons. Your recommendations greatly appreciated!
Love my Disco.. and not quite ready to let it go.
