IIA Transmission Problem.
Posted: Mon Jun 21, 2010 12:34 pm
Hi Everyone,
As those of you who made it to Don's place on Thursday know I had a little transmission mishap on my way in the Lightweight and turned up in a diesel Toyota van instead.
Having conducted some test yesterday with the Truck I can now report the symptoms, what I think may be the problem and how I plan to tackle them.
History.
My transmission has 5000Km on it. It is a D-series spec IIA box with a "B"series transfer case. The transmission was rebuilt by Peter Hurst who has unfortunately been seriously incapacitated by an illness.
The transfer box casing had a crack on the rear cover driver's side stud which was not an issue when I first ran the truck, but became and issue when I installed the Roverdrive.
In the fall of 2008 I rebuilt the transfer case into a new casing and also put some new seals on the clutch throwout assembly. I tried to bring the truck to the 2009 and Founders day and discovered that the transfer case was making a growling noise on the over run and parked the truck having lost my shop space.
Deciding that the issue (after much research) was probably the shims on the intermediate shaft, I gingerly drove the truck to this year's Vandusen ABFM (choosing non Hwy roads and not using the overdrive). Apart from the Over run noise there were no issues.
Anyway I tried o bring the truck out to Don's on Thursday and ran into the following issues.
Symptoms
1) With Clutch disengaged there is a tapping noise from the bellhousing area or transmission area. goes away when the clutch is engaged.
2) First and reverse can be impossible to disengage if the truck is not "rolling"
3) Reverse gear lever is vibrating
4) Truck is growling on the move
What I think may be wrong
1) Main shaft nut has come loose allowing for slop in the gear set.
2) Flywheel has come loose or clutch cover has come loose.
3) Clutch throwout assembly is binding, possibly broken connection collars on between slave and throwout assembly.
What I plan to check and do.
1) Drain gearbox oil and explore with a magnet
2) Check main shaft rear nut
3) Check throwout collars
4) Pull Transmission and check clutch and flywheel.
In Conclusion
Apart from the noise the clutch and transmission is shifting great and everything works well.
If anyone has any other ideas please let me know.
History.
Symptoms
In Conclusion
