Gasket between Swivel Pin Housing and Stub Axel
Posted: Sun May 30, 2010 10:03 pm
I have a leak between the SPH and the Stub Axel on my 62 109" I pulled it apart and rebuilt the brakes and hub assembly and siliconed between the the two but it's leaking again... If if build a gasket from scratch what kind of material should I use or did I just do a crappy job on the silicon? Or better yet, what is the best practice here?
