Closed cell foam
JD
Closed cell foam
#1 Post by JD » Mon Oct 27, 2008 9:23 pm
Going to the big smoke this comming week. Anyone know of a place that sells self adhesive closed cell foam in sheet form?
JD
#2 Post by red90 » Tue Oct 28, 2008 5:11 pm
I have not seen closed cell with a backing. I use camping pads from one of the big outfitting stores. For glue, the best thing is a spray adhesive designed for car interiors and foam. I get that from a car interior place. The normal spray adhesive works OK as well, but not nearly as strong.
Glenn D.
Cross Member
#3 Post by Glenn D. » Tue Oct 28, 2008 8:12 pm
home depo sells it as carpet underlay, ( you will still need spray glue)
rick.m
adhesive
#4 Post by rick.m » Tue Oct 28, 2008 9:18 pm
dont be afraid to use panell adhesive in a tube. you wont be disapointed.there is also a trowel on adhesive for outdoor patio carpets, i had great luck with the interior of my rover with them both. there are a few thousand miles on the truck in 4 years, and no let loose,.rick mx.
#5 Post by red90 » Wed Oct 29, 2008 10:06 am
Glenn D. wrote:home depo sells it as carpet underlay, ( you will still need spray glue)
Do they sell a closed celled foam? You really want closed cell foam so that it does not absorb moisture.
Glenn D.
Cross Member
says its closed cell, I have in in my truck.
#6 Post by Glenn D. » Wed Oct 29, 2008 8:43 pm
dan
Little Wheel
for sound deadening
#7 Post by dan » Thu Oct 30, 2008 11:12 am
Excuse me guys, is this for sound deadening or warmth? I've got to do something for the deafender.
#8 Post by red90 » Thu Oct 30, 2008 11:12 am
Cool and cheap too.
