wiper motor wiring
Posted: Mon Oct 06, 2008 11:02 am
by seapotato
So, I chucked 99.9% of the horrible wiring on my truck ,(among other things.... 8) ), curious about the wiper motor. ( 1971 Series 2 sw) is it one or two speed? it has 3 wires going to it I believe. ( single wiper motor to left of steering column inside dash)
I may end up turfing it too, but I'll check if it works first.
Anyone know which wire does what?
thanks,
r
Posted: Mon Oct 06, 2008 11:14 am
by dfritter
Well, mine's a SIII, but I'd wager that if your switch is a three position, you've probably got the same two-speed wiper motor as me; slow, slow with a hint of urgency, and off.
Posted: Mon Oct 06, 2008 12:28 pm
Get a 4 way switch to allow for the unique Lucas setting of sizzle. And be careful not to let the smoke out as Lucas electrics run on smoke — If you allow the smoke to escape, the electrical device will stop working. :lol:
Sorry I don't have any more positive input. I have the two separate single speed motors in my Series IIa so I don't know how your truck with the rather advanced single-motor-running-two-wipers works.
Posted: Mon Oct 06, 2008 3:22 pm
by seapotato
switch was a nasty looking piece of crap I hurled into the corners of the barn...
with it's being 3 wires, it's probably 2 speed.
I'll apply some volts and see what happens.
Posted: Mon Oct 06, 2008 4:56 pm
by Green Giant
Forgive my ignorance with the mysteries of electrical wiring........ But what is wrong with Lucas? Identification seems to be clear, circuits are basic, connections look to be robust, etc....
Posted: Tue Oct 07, 2008 6:15 pm
by seapotato
:lol: where to start?
here's the third hit on google for electrical failure...
http://www.mez.co.uk/lucas.html
Take your average englishman, if he isn't wearing a red coat and marching up a hill with a musket, he's probably buggering something up. :lol:
LooooKass....
Posted: Tue Oct 07, 2008 7:14 pm
by JD
Ryan,
Re-volting the motor is certainly the way to see if it works...
Posted: Wed Oct 08, 2008 11:00 am
by seapotato
well yeah,
my question was more to check if there was anything sensitive in that motor that wouldn't like having 12v applied, such as a " return to centre" control.
But from the sounds of it, ( and from the look of the motor) there'll probably be a flash of light and a bad smell, and the motor will join all the other lucas crap in my junk bin. :roll:
Posted: Mon Oct 13, 2008 9:16 am
by seapotato
Ok, did a little testing, amazingly the heater fan works, so I think I'll just leave alone, were the heaters ever two speed?
As for the wipers, methinks the motors a little sick, two wires are varying degrees of dead short( one of the two is likely ground, but it's hard to tell which, the ohms are very similar)
and the other is open.
From memory, the three wires are brown, green ,and red with (I think) a green stripe.
is there an online wiring diagram of one of these I can look at? ( or if anyone has one, just let me know what's what.)
Trucks months away from actually needing wipers, but it's one of those easy little jobs I can do when I don't feel like getting too dirty.. :lol:
cheers,
ryan
Posted: Tue Oct 14, 2008 2:19 pm
by Greg S
Ryan, I've got a diagram or two kicking around here and the real MaCoy to look at and compare.
Posted: Tue Oct 14, 2008 5:13 pm
by seapotato
thanks greg,
from the way it seems completely inert, I'll likely be having to take it apart and mess with it.
pretty sure the mechanism that joins the wipers is a touch stiff. :lol:
fitting the diesel in there is next on the list, so the wipers may get the back burner treatment for a little while here.
I'll give you a shout if I'm still too dumb to figger it out... :lol:
2 speed heaters
Posted: Thu Nov 06, 2008 5:48 pm
by Revor
Hi,
My 1969 IIa has a two speed heater, but the second speed simply routes the power through a large resistor in the heater duct to drop the voltage before going through the motor. So the motor is single speed but the switch has the option of sending the power two routes.
The lower speed is really handy for when the cab gets too hot...
Ryan
Re: 2 speed heaters
Posted: Thu Nov 13, 2008 1:41 pm
by seapotato
Revor wrote:Hi,
Ryan
Yeah that's how the older toyotas do it too. big resistor on top of the fan. Simple enough I guess....
I'm delaying all electrical considerations until most of the welding is done...might end up with a painless harness or one out of a bj60. we'll see. Depends what I stumble across.
Still haven't messed with the wiper motor,other than to unbolt it and try to wiggle it loose. I suspect I'll be making a toyota wiper motor fit into that space instead ( because I have a couple, and they're 2 speed)
on the bright side, it steers now.... :lol:
