Disco 1 Stuck transfer lever
Posted: Sat Apr 28, 2007 12:28 pm
Hi there,
Still on the hunt for a Discovery. I have looked at a few now, and 3 of the cars I have seen will not move out of high range. I have seen online that corrosion in the transfer shift linkages can lead to the lever becoming stuck. All 3 owners said they "never use" that lever. Is this as common as it seems to be? What else could cause this?
In the most promising of the cars I saw, a beautiful low km 1995, the lever moves over to the left and the centre diff lock warning light comes on, but it will not move from high to low. (I can't move the lever fore and aft at all...just left to right.) Is there a chance this has stuck with the transfer box only partially engaged? or something more sinister? The warning tone was not there at all. Otherwise it drives perfectly in high range.
Other than this fault, this one looks like a winner. Any advice on where to get this checked out?
Devin Biln
Devin Biln
