Salisbury Axles....
Posted: Sun Oct 22, 2006 9:54 pm
by JD
How can you tell if an axle is a salisbury or not? Front or rear? And are they really as strong as a Dana 60?
JD
MOD 110
Posted: Sun Oct 22, 2006 11:31 pm
by bclandrover
The rover axle has a removable carrier housing, whereas the Salsbury has an inspection cover plate.
It is my impression that the Salsbury is or is very similar to a Dana 60.
Later,
Don
Posted: Sun Oct 22, 2006 11:35 pm
by JD
Carrier houseing or inspection plate ... where.... front or rear axle ... near the wheels? Sorry don't really understand your anser Don.
JD
hmmmmm
Posted: Mon Oct 23, 2006 6:40 am
by nakedbarra
On the back of the pumkin (center big bit ) and I believe salsbury are only on the back of land rovers only not the front.
Posted: Mon Oct 23, 2006 8:38 am
OK....
The Salisbury is in fact a Dana 60, made by Dana for Land Rover.
There are few little differences. The Rover version uses a different R&P than normal 60s. The ring mounting holes are a slightly different diameter and the pinion bearings are different. The rover version uses a 4 pinion center whereas most 60s use a 2 pinion. Anywho, the center is as strong as any 60 out there if not stronger.
Now the down side.... They use the regular Rover 24 spline (1.24") halfshafts which are a lot weaker than the center. Regular Dana 60s use 30 spline (1.31") shafts and HD ones use 35 spline (1.5") shafts. Changing to 30 spline is fairly stright forward. 35 spline is possible, but more involved and expensive.
Look a like
Posted: Mon Oct 23, 2006 8:52 am
by JD
Thanks for all the replies.
But I still don't know what I'm looking for on the outside of the axle that would identify my rear or front axle as a Salisbury. Having an MOD 110 I've been reliably informed that my rear will be a Salisbury but my front won't... but I'ld like to be able to see for myself. Can't seem to find enough documentation to identify them.
looked for an inspection plate on my rear axle. ?? Couldn't see one. There is a big bolt on cover .... similar to my old Dodge, but there is no "plate" on top of that as such.
So what am I looking for on the outside of the axle? What shapes, bolts, sizes?
JD
here is a pick of a salsbury
Posted: Mon Oct 23, 2006 10:01 am
by Glenn D.
correct me if im wrong.
http://www.pangaea-expeditions.com/imag ... xle350.jpg
or
http://www.washbrook.net/images/d90salisbury.jpg
the d90 usually has no rear unboltable cover on its axle, the salsbury axle does.
Posted: Mon Oct 23, 2006 10:23 am
hmmmmm
Posted: Mon Oct 23, 2006 12:44 pm
by nakedbarra
If you have a rear bolt on cover you have a salsbury
asks ell?
Posted: Mon Oct 23, 2006 5:20 pm
by JD
Thanks for all the replies!
I've got it sorted out. Bolt on cover = Salisbury. Cool. Pangolin web site interesting as well.
JD
