Possible Lifter issue
Posted: Sun Jul 13, 2025 10:55 am
So my Disco (2004 Discovery II) hit 300000km and has decided to grace me with a new intermittent noise. It appears to be a loud lifter tick, it increases with rpm, disappearing at about 700 -750 rpm.
The truck run fines and other than an occasional low temp code has no other codes or issues.
I am running Castrol 10/40 plus a shot of ZDDP, oil was changed in late November oil is golden; however, I did run Royal Purple HPS 10/40 prior to this last oil change.
Oil pressure at idle and 174f is about 20 psi 660 rpm, rising to 45-50 psi at 2000 to 2500 rpm
The noise typically (when it appears) shows up at idle after getting up over 180F running temp for some time.
My normal temp is 174f, 177 running the ac on the freeway in the current ambient of 30F outside temperatures.
The noise is easily heard with the window down, I can not hear it with the window closed.
It is a very noticeable metallic tap on the left side, it sounds to be at the top of the engine rather than the bottom. As rpm increases it turns into the "normal" sound of a lifter tick.
I heard it when stopped against a concrete barrier, accelerated, then let the disco coast to a stop with the window down, the tick did not return.
My suspicion is I have a partly clogged, failing or sticky lifter, there could be a possible rocker arm issue but it does not read that way to me.
Does anyone have any other suggestions ? I am about to have a kitchen and floor reno starting, so I do not have a lot of time to tear into things. I would love to take into a shop for diagnosis but it has to wait until after the reno
