Brake Lines
Posted: Sat Dec 28, 2024 9:53 am
Ok, another (maybe dumb) question or two.
1. I'm running new brake lines on my chassis. My 88 swb I'm building is a LHD but for some reason the previous lines (and bracket for the rear line that meets the flex hose) were on the right hand side (the passenger side) of the chassis. I could switch to the driver's side but then id have no bracket on that side for the rear flex hose and I'd have to screw in new clips all along the left side of the chassis. Is it ok just to run the brake line along the passenger side and come up and across to the driver's side along the bulkhead?
2. I am switching to a dual circuit servo brake system from the old single line system. In the single line system, the rear brake line that runs from the rear flex hose, along the chassis, joins a 3-way junction at the bulkhead, with the brake switch in one of the ports and the line going up to the MC in another. In my two way system, as my brake switch will be on the MC, do I need a 2-way (basically and elbow joint) at the bulkhead still for the line going up to the MC or can I just extend that rear brake line and have it run without a junction straight up to the MC? (I should add, I can't seem to find a two-way junction, only 3-way)
3. Last (dumb) question.. with the front brakes, I have seen diagrams that show a short, hard brake line from the caliper attached to the flex hose running to the bracket on the chassis. But I've also seen the flex hose direct from the caliper to the bracket on the chassis without a hard line. Can I ditch the hard line altogether and just go with the flex line? It would seem almost more practical to do that. But then the question is, do I still use the same length of flex line or do I go with a longer flex line, my concern then being a kink in the line when the wheel is turned and the leaf spring compressed.
Any thoughts would be GREATLY appreciated!
