1997 Land Rover Wolf 110 TUM HS FFR Hardtop
Posted: Mon Mar 20, 2023 10:53 am
I am selling a few of my Land Rovers to thin the herd.
First one up is my 1997 Wolf built July 31, 1997 so eligible to be imported to the USA also.
From Wikipedia;
Engine choice - When the Wolf was designed the engine in the civilian Defenders was the Td5. The Ministry of Defence preferred the 300Tdi for the Wolf because the electronics in the Td5 were more complex to manage in the field.
Reinforced rear axle - Salisbury axles kept breaking. The axle was therefore redesigned using stronger internals, hubs and outer casing, making one of the strongest land rover axles ever made
Fiberglass roof - simpler to manufacture over the raised height of the roofbars than the Defender aluminium roof.
Side-mounted spare wheel - Land Rover tried to mount the spare wheel caused the mountings to break free and it was too heavy for the bonnet
Chassis - The chassis is considerably different in design to the standard Defender chassis even though it looks similar. The side walls are standard, most of the rest is bespoke. The additional rear load bed mounting was to take increased weights as the standard chassis kept punching big dents in the rear floor.
Side lockers - he unusual shaped doors were simply to take full jerrycans more easily.
24 volt electrics
Internal roll cage
'Wright Off-Road' Matting System - reduce noise and heat from the transmission.
Power steering
This is equipped as it came from the MOD, cool items such as the rifle mount between the front seats and racking for the radio are as the MOD left it.
Any questions, please give me a call. 604-619-1418
The mileage showing is 77,400 kms.
Price is $50,000
The vehicle is at Clapperton Ranch near Merritt.
From Wikipedia;
24 volt electrics
Internal roll cage
Power steering
Price is $50,000
