ISO rear differential/Axle
Posted: Sat Feb 19, 2022 5:58 pm
by Turton
Hello, does anyone have a rear axle or differential in good working order for an 88" for sale? ours in our 1969 has far too much play for my liking.
can these be rebuilt locally (Kelowna)?
any help would be appreciated
thanks
Geoff
Re: ISO rear differential/Axle
Posted: Sat Feb 19, 2022 8:08 pm
Pull the halfshafts and see how much wear is in the splines. That could be a lot of the play you are seeing.
The diff is pretty easy to work on. Any mechanic could set one up.
Posted: Sat Feb 19, 2022 11:44 pm
by Turton
Humm, I think I’ll take a look next weekend
Thank you
Posted: Sun Feb 20, 2022 8:47 am
by jacobko
As red90 mentioned, check the splines on your drive flanges, and half shafts. I have drive flanges, half shafts, and differentials if you need any. Located in Nelson, but I plan on driving through Kelowna in the spring.
Posted: Sun Feb 20, 2022 5:43 pm
by Tony4921
I have a few 4.7:1 diffs if you need one.
Posted: Wed Mar 16, 2022 8:09 am
by Turton
Just wanted everyone to know, new axles and flanges solved my issue. I didn’t think that small amount of play would turn into so much slop in the diff.
Thanks for all you help.
Geoff
