Clutch question 67 IIA 109 with six cylinder Chevy Conversion
Posted: Sun Nov 29, 2020 9:18 am
Hello,
I'm planning to put a fresh clutch in my 1967 109 Six Cylinder that has a Chevy 250 installed with Scotty adapter.
Will a normal Land Rover IIA clutch disc and pressure plate work for this? From what I've gleaned from Google, which might be wrong, the conversion uses a Vega (!) flywheel which matches up to the Land Rover pressure plate bolts. I'd like to get the right parts before I take the truck apart.
Paul in Victoria
Paul in Victoria
