Hello Roverlanders!
Any chance that someone knows source for a working TD5? I have been quoted 20,000CAD to replace my hydro-locked one. The head gasket and head seem to have failed. Conn rods may be a problem as it won't budge... and I'm not sure my 110 is worth that much!
TD5 hydrolocked! Source for another?
Ragged Edge
- Rookie
Re: TD5 hydrolocked! Source for another?
https://www.turnerengineering.co.uk/strippedengines
https://www.turnerengineering.co.uk/lbb ... 2x20634465
In the end a local rebuild will probably be cheaper. $20000 is a crazy price.
Tony4921
Where are you located?
Where did you get that quote from :shock:
Was the engine shut off as soon as it was hydro-locked? Depending on what damage you did, it could just be a bent conrod or blown head gasket. All the parts are likely available locally (Vancouver) and I would think even if an independent work shop did the work, it should be more like $5000. (unless the block is cracked).
First thing would be to remove the head and evaluate the damage before giving up on the engine.
Hope its not too bad for you!
mel rover
- Half Shaft
I dont know who you talked to but I brought in a td5 for 800 pounds and 300 pounds for shipping td5 are cheep let me know if I can help
Rob Mills
Rob Mills
