I suspect your insurance could be VOID if you have not properly insured for modifications to your Land Rover.
Here is the conditions that would require "modified vehicle" status according to the form on ICBC's website:
The ICBC modified vehicle information page:A motor vehicle must be registered as a modified motor vehicle of a manufacturer's make if the motor vehicle (passenger or light commercial):
• has the shell of body, coach or cab from the original manufactured motor vehicle; and
• has an altered body that resembles, but is no longer identical in appearance to the original body of the motor vehicle; or
• has had one or more of the following components replaced or altered:
– suspension (if altered more than 10 cm)
– frame
– drivetrain
– engine
– steering
– braking mechanical component (disk brakes)
– fuel type.
https://www.icbc.com/vehicle-registrati ... icles.aspx
The new application form, dated 09/2019:
https://www.icbc.com/vehicle-registrati ... dified.pdf
