Whitworth Wrenches
Posted: Thu Oct 31, 2019 7:31 pm
by Hamberger
Any easy way to spot an old British Wrench when going thru a box or assorted wrenches at Flea Markets, Garage Sales, Pawn Shops? Is there a tell-tale stamp or something to speed up the process?
Re: Whitworth Wrenches
Posted: Thu Oct 31, 2019 7:33 pm
by rayhyland
Often there will be a W stamped by the size
Posted: Fri Nov 01, 2019 7:43 am
by Hamberger
excellent.
Posted: Mon Nov 04, 2019 9:18 pm
by Hamberger
Found an old wrench today that says 7/16 but is more like a 5/8.......there is an uppercase "B" inside a shield on the handle
Posted: Tue Nov 05, 2019 7:24 am
Yes, that is whitworth. 7/16" refers to the thread size of the bolt.
Posted: Tue Nov 05, 2019 12:20 pm
by bsa_m21
The B likely stands for BSF - British Standard Fine.
http://www.baconsdozen.co.uk/tools/conv ... charts.htm
M.
Posted: Wed Nov 06, 2019 9:05 am
by harv
I suppose actual Whitworth wrenches would be nice to have, but in my 25 years of owning my 2A I've done almost every job there is to do using SAE and metric.
Posted: Fri Nov 08, 2019 11:54 pm
by oldgravy
I could not get the hubs and backing plates off of the axle case of my S2 without a whitworth spanner.
Mind you on the other axle I drilled and split the nuts with a chisel so... 🤷🏻‍♂️
Posted: Sat Nov 09, 2019 9:18 am
by harv
From memory, I think I needed to "tap" (aka pound) a metric socket on those.
