Series 1 107" 5 dr.
Posted: Mon Jan 28, 2019 8:12 am
by 4wheelstogo
After much planning and a stroke of courage I decided to plunge into my restoration of this lovely 1956 107" 5dr SW.
(165.06 KiB) Downloaded 529 times
(232.82 KiB) Downloaded 529 times
At first glance under the hood (no its not an actual rats nest :roll: )
(335.96 KiB) Downloaded 530 times
Just trying to get to the frame and compete my full assessment to have some idea of the mess I have got myself into :shock:
(437.74 KiB) Downloaded 529 times
Tune in for more to come soon. Please dont hesitate to offer any friendly advice/ leads on parts/a shoulder to cry on...
Re: Series 1 107" 5 dr.
Posted: Mon Jan 28, 2019 7:21 pm
by Rambler
Thanks for sharing your smart S1 LWB station wagon, and good luck with the rebuild. I see this has a SU (possible Stromberg) carb fitted to the 2.0l engine. I’ve seen this on a few Series ones.
Posted: Fri Feb 01, 2019 9:45 am
by 4wheelstogo
A keen eye sir. Luck is exactly what I need.... This was what I was looking at yesterday :|
(276.15 KiB) Downloaded 468 times
Posted: Fri Feb 01, 2019 11:17 am
by franko
😮 that is some nasty rust right there sir. I think you might need to find a frame.
Posted: Fri Feb 01, 2019 1:30 pm
by bsa_m21
Ouch! I think the word "might" is a bit of an understatement. Unfortunately 107" frames are not the most common spare found.
This firm has a number of rebuild replacement sections. Shipping from the UK can be a bit pricey though.
http://www.pegasusparts.co.uk/ourshop_9 ... d-109.html
And here is a link to a 107 wagon rebuild log to encourage you to continue. :|
https://www.jakewright.com/vehicles/lan ... er-3-years
Posted: Mon Apr 22, 2019 10:30 am
by mjc_seattle
I'd check in with Ike Goss at Pangolin https://pangolin4x4.com/home He owns a couple of these gems. He may be able to help sourcing the frame if your's is truly past fixing it. The 107SW is a very unique frame because it doesn't match the 109SW made in 1958/59 and is different from the 107 truck. The rear cross member is unique only to the 5 door SW version. Lots of other parts are very source-able. Do you have the rest of the roof and safari skin?
I dove into a restoration of a 107SW a little while back... so much fun. Happy to answer any questions I can or point you in the right direction for things I don't know. I do know that is the incorrect carb for the 2L engine. Minor problem at this stage! ;)
Here's some pix of mine. Keep the updates coming!
Matthew
Seattle, WA
