Rebuilding Duffy
StuartC
- Wing Nut
Re: Rebuilding Duffy
Anyone know the significance of these numbers on the transmission of a 1959 series 2 stn wagon....?
- (48.06 KiB) Downloaded 288 times
- (61.3 KiB) Downloaded 287 times
oldgravy
- Captain Crunch
Yours looks like it might be in decent shape? The special nut on my mainshaft (heh) is mangled.
I am building a parts list...
StuartC
- Wing Nut
Yes, I believe it is in decent shape (has not been driven since 1985)......although there is no reverse.
It is out of the vehicle, on the bench, so I will dismantle it and investigate.....
Will be interested in your progress and what you find.
oldgravy
- Captain Crunch
I think I have concluded that, due to the general age and heavy wear on the running components in the vehicle, (no surprise) the gearbox is beyond saving. :( :( Possibly the transfer box also.
1st gear is worn and chipped; 2nd and 3rd are worn. Almost every sliding surface is well worn.
The mainshaft looks okay; and the layshaft looks okay. But the selector shafts have rust on them, the synchro looks like it has some rust spots on it as well, and with the price of replacement parts it could be too expensive to replace everything. :?
Pretty sure the mainshaft distance piece isn't supposed to be, you know, broken. Heh!
I wasn't going to pull all this stuff apart, figuring it would be fine if I just left it. In retrospect, I'm glad I took the time to strip it and do more than a cursory inspection of the parts.
- (56.56 KiB) Downloaded 257 times
- (65.68 KiB) Downloaded 256 times
- (72.78 KiB) Downloaded 261 times
- (57.74 KiB) Downloaded 255 times
- (92.98 KiB) Downloaded 258 times
oldgravy
- Captain Crunch
Here's the 'mud' I mentioned:
- (86.77 KiB) Downloaded 257 times
- (93.81 KiB) Downloaded 255 times
StuartC
- Wing Nut
ouch....looks like someone was trying to learn how to shift without a clutch.
oldgravy
- Captain Crunch
It's a mess. I will have to post more on what I have discovered soon. 😑
oldgravy
- Captain Crunch
Here's the damage. A list of parts that *for sure* need replacing.
I am hoping I can save the shifter linkages, maybe the synchro? and the output shaft on the transfer box.
In addition I need all the parts that were missing (the entire yellow lever), the whole clutch pivot assembly (shot), and every bearing, seal, and gasket.
oldgravy
- Captain Crunch
New blog post: I have begun taking the gearbox / transfer unit apart and separating into its major components.
oldgravy
- Captain Crunch
And because I do these things in bunches, it would seem, I just added another post on disassembling the main gearbox.
Thanks for the update, I see your going in deeper :shock:
If your like me you will feel like a dentist doing Heart surgery !!
Like you mention in your blog, taking it apart and putting back is cheap if you don't need to replace parts, Good luck!
Think how much lighter Duffy will be without all that muck and grime 8)
Looking forward to the next update.
oldgravy
- Captain Crunch
Heh, I feel like a clown attempting to construct a skyscraper. Or as my old man is fond of saying, like 'a one-armed poster hanger in a stiff breeze.'
I am afraid all that labour is for naught. I don't think I can afford the replacement parts. A second gearbox, at least, will have to be sourced... and probably a t-case. 🙁
Ah well. It definitely helps knowing others have gone before me! Having a community of knowledge is most welcome.
TimberPig
- Bumper Sticker
The biggest challenge with Series gearbox rebuilds is no matter where you start, the newest Series 3 boxes are 40 years old, with 2a,2 and 1 being 51 to 75 years old, and many have had rough lives. Most haven’t been as abused as yours, but most parts trucks are likely to be rougher and their gearboxes are probably going to have many parts needing replacement just like yours.oldgravy wrote: Tue Feb 14, 2023 8:50 pm Heh, I feel like a clown attempting to construct a skyscraper. Or as my old man is fond of saying, like 'a one-armed poster hanger in a stiff breeze.'
Add to this that getting quality gearbox parts can be a challenge as the quality of many current parts for these gearboxes is less than the original parts, and NOS parts are getting harder to find and pricey.
Buying another gearbox could be a crapshoot, as you may get one better to start from but it may be as bad or worse. Without cracking them open, it’s hard to say. Best bet is if you can find one someone has already checked out to confirm condition.
The one advantage to fixing what you have is you know where you are at, and once it’s rebuilt you’ll know what you have. Either way, you’re going to end up going through the whole thing. Just the amount of parts replaced that might vary, depending on how good a used gear/transfer box set you can pick up.
oldgravy
- Captain Crunch
Current parts total: £1,451.84.
Before shipping, taxes, and duty.
It's a mix of genuine parts, where available, and whatever is available if genuine isn't. That's the total from my cart at Craddocks. I've put everything into a spreadsheet and I'll be working through lrworkshop to see if it's worth splitting an order into two but... I rather suspect this is what it's gonna be.
At current exchange rates it's $2374.
oldgravy
- Captain Crunch
oldgravy
- Captain Crunch
Stymied by the gearbox I decided to clutter up to workbench even more by taking a look at the defender 200tdi I have as a donor motor for the project. If it's a good one, I will pick up a disco timing chest and front cover / water pump so it hopefully drops right in.
This motor was bought by the previous owner off eBay. Serial number is ground off so it's likely a stolen motor.
Don't care all *that* much as long as the head is good.
- (120.95 KiB) Downloaded 116 times
- (112.22 KiB) Downloaded 116 times
oldgravy
- Captain Crunch
Looks like someone's been in here.
- (94.21 KiB) Downloaded 119 times
- (90.16 KiB) Downloaded 115 times
oldgravy
- Captain Crunch
oldgravy
- Captain Crunch
I see I have written up a few new blog posts but none have been posted here. Whoops.
In my last entry, in a bid to keep moving forward I decided to pick up a series 1 gearbox from a collector here in South Surrey, hoping that I could salvage some of the internal components and reduce the cost of my transmission rebuild... only to find out that sadly it, too, was quite worn and I was able to salvage almost nothing from the 'box. :(
Finally, frustrated with gearbox problems (and no money to solve them) I turned my attention to another thing I could work on, starting to strip down my 200TDi.
Keen-eyed observers will note that I have changed some of the naming conventions in my blog, so previous links are probably broken.
oldgravy
- Captain Crunch
TimberPig
- Bumper Sticker
Looks good, but as I understand it you’re leaving the POR 15 as the top coat? It isn’t UV tolerant and degrades if not top coated, so it would be better to top coat it now rather than needing to tear the truck down again later when the POR 15 starts to show the degradation.
He used POR15 top coat which is UV stable.TimberPig wrote:Looks good, but as I understand it you’re leaving the POR 15 as the top coat? It isn’t UV tolerant and degrades if not top coated, so it would be better to top coat it now rather than needing to tear the truck down again later when the POR 15 starts to show the degradation.
TimberPig
- Bumper Sticker
I missed that part when I read it. Oversight on my part.red90 wrote: Thu Nov 23, 2023 5:25 amHe used POR15 top coat which is UV stable.TimberPig wrote:
oldgravy
- Captain Crunch
Yep, the exact paint I used is on one of the photos. I was aware of the UV issues with (standard, not top coat) POR plus, I figured it wouldn't be better than any other coating on top of new galv.
I don't know much about coatings, so I went with one that I had used previously on my axles. I had some ideas how it might work.
It seems okay, but as with most things time will tell. I've also heard that Eastwood chassis black is pretty good?
oldgravy
- Captain Crunch
