1965 Series IIa 109" Build
Koopsy
Learner Driver
Re: 1965 Series IIa 109" Build
#26 Post by Koopsy » Fri Jan 12, 2018 4:52 pm
My goal was to start the engine and make sure everything was okay and that the transmission went into gear. I bought a brand new wiring harness with alternator conversion. It made the installation super easy and straightforward. I made my own alternator brackets as well. I had 2 radiators pressure tested and both leaked so I decided on getting a brand new one. I realized I forgot to paint the gauge and switch mounts so I cleaned everything up, painted, and put it back together. //uploads.tapatalk-cdn.com/201801 ... 78bed5.jpg//uploads.tapatalk-cdn.com/201801 ... c9583d.jpg//uploads.tapatalk-cdn.com/201801 ... d8f462.jpg//uploads.tapatalk-cdn.com/201801 ... 408c70.jpg//uploads.tapatalk-cdn.com/201801 ... d3bfea.jpg//uploads.tapatalk-cdn.com/201801 ... 4bfb60.jpg//uploads.tapatalk-cdn.com/201801 ... 21b10b.jpg
Koopsy
Learner Driver
#27 Post by Koopsy » Fri Jan 12, 2018 5:33 pm
mepham55 wrote:That’s looking great! Very nice work. I like the “paint booth”, when I painted my truck I ended up painting all my tools with a nice limestone(best colour) dusting.
I agree, you can never have enough space. My garage/shop I just built is no where near big enough! I have my 1966 SWB and 1961 SWB both crammed in and now have 2 1959 SWB’s waiting outside for their turn!
Haha yes the floor has a nice limestone dusted rectangle on it now. I’ll be putting down a tarp and I’m definitely going to step up the ventilation when I paint the rest...
I have a ‘70 SWB outside waiting its turn. It was complete until i started robbing a few parts here and there... it’s going to have to wait until the racecar is done. I don’t know where I’ll keep everything once they’re too nice to leave outside...
DrRangelove
Hot Manifold
#28 Post by DrRangelove » Sat Jan 13, 2018 11:26 am
The standard of this build is impressive!
Koopsy
Learner Driver
#29 Post by Koopsy » Sat Jan 13, 2018 1:42 pm
DrRangelove wrote:The standard of this build is impressive!
Thanks! One step at a time
Koopsy
Learner Driver
#30 Post by Koopsy » Sat Jan 13, 2018 1:49 pm
Over some time off at Christmas I was determined to get it running. I finished up the wiring and used an old gauge I had to make sure it had oil pressure. Getting fuel to the carb was the hardest part, we finally determined that there wasn’t a good enough seal around the sediment bowl so I made a new gasket and it made a world of difference. Once that was sorted I hit the ignition and It was the easiest engine start up I’ve ever had, half a crank and it fired right up without an issue. The carb started to leak so I’ve ordered a rebuild kit. //uploads.tapatalk-cdn.com/201801 ... 3e901e.jpg
Koopsy
Learner Driver
#31 Post by Koopsy » Sat Jan 13, 2018 1:55 pm
So this is where I’m at now... finally...
The starter is sort of sluggish and before I could start the engine again to try and put it into gear, it was so weak it would barely turn it over. I tried to make a better ground to the frame and several different batteries but it didn’t make a difference. I’ve ordered some new brushes and I’ll give it a good clean inside. Hopefully that will make the difference. While I’m waiting for that I ran lines for the clutch and brakes. //uploads.tapatalk-cdn.com/201801 ... 0de525.jpg//uploads.tapatalk-cdn.com/201801 ... 21c05b.jpg
Koopsy
Learner Driver
#32 Post by Koopsy » Mon Jan 22, 2018 12:17 pm
Replaced the brushes in the starter and it still turned slow so I went through all of the ground and power cables making better contact with the chassis and now it cranks like it never has before!
I received my custom gauges in the mail this week as well so I spent the weekend wiring them up. I used speedhut to create some awesome gauges to closely match the original and match the others best as possible. We also made up a little panel to house them, I think it turned out well!
//uploads.tapatalk-cdn.com/201801 ... c464ed.jpg//uploads.tapatalk-cdn.com/201801 ... cd6bc0.jpg//uploads.tapatalk-cdn.com/201801 ... 90e2ce.jpg
Rambler
Over Inflated
#33 Post by Rambler » Mon Jan 22, 2018 5:37 pm
Those look super smart. Wasn’t aware if the speed hut site before. Thank you. I might try for something similar. Just need the land rover logo image to include :-)
Koopsy
Learner Driver
#34 Post by Koopsy » Mon Jan 22, 2018 5:41 pm
Rambler wrote:Those look super smart. Wasn’t aware if the speed hut site before. Thank you. I might try for something similar. Just need the land rover logo image to include :-)
Ya I hadn’t heard of them before and I got a set for the racecar and they worked great. You’re able to customize right on the site and then if you need other stuff done, you just email them and it’s a very reasonable price for custom work. Something I learnt this time around was to ask to have the speedhut logo removed. It’s $10 per gauge but makes them look more authentic without it. You could have them put the the smiths logo or whatever in its place! I had them put the Land Rover logo and then put the red bar from 100 degrees up on the water temp gauge like the original. They go on sale quite often as well, that’s the time to do it!
Rambler
Over Inflated
#35 Post by Rambler » Mon Jan 22, 2018 6:43 pm
Thank you very much, that is great to hear. I will wait on their sales!
