Re: Meet Garth! - 1973 Series III
Posted: Tue Oct 29, 2013 4:28 pm
Loving this thread, keep it coming.
Forum for Land Rover enthusiasts
https://roverlanders.bc.ca/roverforum/
First: Try posting it in the proper forum so people can answer it for you, not everyone will be reading it on your build page.flipstah wrote:Bah, winter did something to Garth.
FML. Having carburetor issues.
The fuel is leaking out and not creating a vacuum to feed, so it won't cold-start.
Battery is fully charged and the engine is warm but it won't finish cranking.
:banghead:
From what I understand, when you pump the gas, the carb is fed gas so that you can start it. The choke is up and once it starts, you level out the choke until idle has calmed down then you push the choke all the way then you're on your merry way.Greg S wrote:First: Try posting it in the proper forum so people can answer it for you, not everyone will be reading it on your build page.flipstah wrote:Bah, winter did something to Garth.
:banghead:
Try the Question and Answer page for technical and Mechanical issues. http://www.roverlanders.bc.ca/roverforu ... um.php?f=5
Second: Sorry, I've been involved with theses things for many years and have no idea what you just said. A fuel leak is preventing a vacuum? Won't finish cranking?
Okay, bear with me for awhile. Here are some real basic concepts of how a gasoline engine with a carburetor works. Please take note: I am NOT being condescending or mean to belittle anyone in any of this. People now have grown up never having had anything to do with carburetor engines so have no concept of the process or terms. The principals are significantly different from a fuel injected engine and many people never have to consider them. Personally, I can't understand the basic concepts of modern fuel injected systems with their electronic.flipstah wrote:From what I understand, when you pump the gas, the carb is fed gas so that you can start it. The choke is up and once it starts, you level out the choke until idle has calmed down then you push the choke all the way then you're on your merry way. Whenever I pump the gas, fuel is leaking near the carb. Smoke is sputtering out of the exhaust but it just won't finish the ignition process.
Yes, yes! replace the fuel line! Does yours have the mechanical pump on the engine? If so, it is a bit inefficient in my opinion to have soft rubber suction line between the tank and pump. In a rear mounted station wagon tank, at the back of the vehicle, as far as my experience goes it does anyway. You seem to lose efficiency, possibly by the hose contracting on suction strokes. Maybe not, just an observation that lead me to installing a $40 electric pump (4 to 7 psi) near the tank. Most of my fuel delivery problems disappeared after that. Ran it in series with the mechanical one.flipstah wrote:...I found this kit on the internet and was wondering how complex is it to do? It looks simple but that can be deceiving:...
I'm also planning to replace the fuel line because I found that the hose leaks in the undercarriage as well.
You mean like this?Greg S wrote:Yes, yes! replace the fuel line! Does yours have the mechanical pump on the engine? If so, it is a bit inefficient in my opinion to have soft rubber suction line between the tank and pump. In a rear mounted station wagon tank, at the back of the vehicle, as far as my experience goes it does anyway. You seem to lose efficiency, possibly by the hose contracting on suction strokes. Maybe not, just an observation that lead me to installing a $40 electric pump (4 to 7 psi) near the tank. Most of my fuel delivery problems disappeared after that. Ran it in series with the mechanical one.flipstah wrote:...I found this kit on the internet and was wondering how complex is it to do? It looks simple but that can be deceiving:...
How complex is it to rebuild a twin barrel carb? I have never had one apart. Sorry, can't help you with that one but other carbs I've had apart have been reasonably easy. You must keep the parts in order, clean and kept track of. Don't use silicon gasket goop on them or you're asking for problems. Learn how small an amount of force is needed to tighten things up. Too much torque on those little machine screws will strip or break them or compress gaskets incorrectly. Download instructions and a diagram and have them right beside you to set it up properly.
Thanks for this tidbit, Greg. I thought that since the starter is going then stops but the engine didn't start, that would be the case but from what you're telling me, it's the carb. Again.Greg S wrote: If your timing is too far advanced, it could be firing too soon Before Top Dead Centre (BTDC) and actually forcing the piston down BTDC so it's backing up a bit. If it was turning faster, the inertia would keep it turning the right way. That is why there is a heavy flywheel, to help retain inertia between power strokes. Try setting your timing a bit closer to TDC then try it.
Yikes - all that pumping is dumping a *ton* of fuel into the carb!! After that - it would be cranky starting even if everything else was A-OK...flipstah wrote:Okay, so ignore my dad pumping the accelerator like a mad man haha.
And by that I mean: choke open and pedal to the floor and hold it there.RobTheGob wrote:I'd likely be doing the opposite - trying to get some of the fuel out of the carb throat.
That actually made starting easier. Thanks for that.RobTheGob wrote:And by that I mean: choke open and pedal to the floor and hold it there.RobTheGob wrote:I'd likely be doing the opposite - trying to get some of the fuel out of the carb throat.
WAY less pumping! There is a lot of fuel pedal pumping in your videos...
Are you sure you are adjusting the idle speed screw in video #2? Keep in mind there is a idle mixture screw as well (there could be two. Some of those dual throat carbs have two idle circuits) and it almost appears to me that you may be turning that...
I have no idea how to do that. Do you have a typical walkthrough for this?red90 wrote:Sounds like your mixture is off.
Have you checked the timing, and that vacuum and centrifugal advance are working?
