Page 2 of 2
Posted: Fri Jan 28, 2011 2:56 pm
by franko
Well to tell the truth is STILL not finished,not much left but its a never ending project. ALthough I can see the light at the end of the tunnel.
Should at least have it running soon maybe by mid Feb. Will keep you all posted .
Posted: Sat Jan 29, 2011 6:37 am
by rezdiver
LOL,
the light at the end of the tunnel ususally dims down once you put the motor and tranny under the tunnel and close the hood to block the light.
any more pictures?
franko wrote: ALthough I can see the light at the end of the tunnel.
Posted: Sun Jan 30, 2011 8:50 am
by franko
haha right right, na not really any progress pics. But I have a few other ones I could post up I guess.
Posted: Mon Mar 07, 2011 9:20 pm
by rezdiver
Franko,
you done yet? I am. first big drive after the swap was today in the Iltis. I was going to drop by and have a look at the progress, are you going to be up to the shop anytime soon?
Posted: Sat Apr 09, 2011 2:01 pm
by franko
So did you ever make it by the shop? Its still a work in progress,but Its coming along for sure little bit at a time. Chester also is building a house so that takes up some of his time for sure.
How did yours work out,do you like the 1.9 VW swap? Oh and if you still have those wheel spacer I may still take them.
Posted: Sat Apr 09, 2011 4:13 pm
by Doc Tari
Franko,
Looks like it's coming along great. Look forward to seeing it perform on the trail.
Reza, how about a few pictures of your conversion?
Posted: Sat Apr 09, 2011 6:23 pm
by rezdiver
Franko,
Unfortunately the spacers sold a few days ago.
I never made it to the shop yet, not enough time in a day, gonna go soon, i have not chatted with Chester for a while.
the swap is good so far, lost a bit of top speed but i still have not changed any gearing, i think i will change out 4th gear if i can find a matching old tranny from an old audi 4000 or a porsche 924.
she has way more power than before and i dont need to go fast anyways. she is happy between 90 and 95 on the highway.
working on veggie oil conversion as we speak.
will post up some pics on a new thread so i dont clog up Frankos build.
Posted: Thu Nov 24, 2011 8:19 am
by franko
TEASER VID.
So before I can even get it moving I run into this issue.
The trans will not go into gear; the t-case is in gear and I can feel the trans grab very slightly when shifted into forward or reverse but it's not fully engaging. There is ATF in it. I don't think it's a transmission shifter or linkage adjustment issue because I can slowly move it through the gears and it doesn't ever seem to fully engage. It does not engage enough to ever move the truck; only enough to barely bump it ahead or back. This could be a dirty trans filter causing the pump to not get enough oil or maybe something else. It is not likely electrical.
Anything that you guys can think of that we have not done or forgotten to do. Hoping that rezdiver has my answer and can swing over and get it moving lol.
Posted: Wed Jan 04, 2012 9:37 pm
by e.prevost94
Any progress lately?
Transmission issue
Posted: Fri Mar 30, 2012 10:59 am
by romayama
Could not figure out the PM reply, sorry.
I'm having exactly the same transmission issue with my conversion to Isuzu 4JB1T. It started howling at idle and ended up not catching the gear at all.
http://design-engine.ca/vehicles/Diesel/
http://design-engine.ca/vehicles/Diesel/Rebuild/
Also working on dual tank WVO conversion. Can share the drawings for custom under body tanks (2 x 25L).
I also bought a used tranny and currently contemplating a swap.
I, however, suspect one thing that could have caused the trouble: Drive plate to Torque convertor gap - is yours same as it use to be with gas guzzler? If incorrect, this may have destroyed torque converter.
I bought an ATF pressure gauge off ebay for $46 and going to run a pressure line test prior to doing a transmission swap. There is also a tap for Torque converter pressure check, i just have to figure out which one of two.
Posted: Sat Mar 31, 2012 4:16 pm
by HeadDamage
Sounds like a torque converter problem or some other line pressure issue.
Tranny
Posted: Sat Mar 31, 2012 10:37 pm
by romayama
Sounds like it. Thanks.
I'll conduct the series of pressure tests and will post my findings soon.
Re: Diesel swap OM617 into a Disco.
Posted: Tue Aug 14, 2012 7:48 am
by franko
Just a short teaser vid,she runs drives and shifts smooth.. More updates to come.
http://i302.photobucket.com/albums/nn87/franko_6962/th_IMG_1462.jpg
Posted: Sun Nov 04, 2012 10:09 am
by franko
Posted: Sun Nov 04, 2012 10:15 am
by franko
Oh and do any of you,have any tips on to how to deal with this mess? :evil:
http://i302.photobucket.com/albums/nn87 ... G_1596.jpg
http://i302.photobucket.com/albums/nn87 ... G_1595.jpg
Does anyone locally stock the boot floor replacing kit?
Posted: Sun Nov 04, 2012 10:16 pm
by e.prevost94
None that I know of. That rot is nothing compared to my disco. The twat that owned it before me thought it would be best to repair the rot with ROOFING TAR! Sometimes you gotta wonder. I just ended up paching it up with sheet metal.
Posted: Sun Feb 10, 2013 1:05 pm
by kentworks
franko... I see that you dumped the A/C compressor because it interfered with the steering box... lucky for you, you live in the great snowy north. But for those of us in in the sunny south, what are your thoughts on keeping the A/C intact?
Is there a spot on the opposite side of the engine from the steering box where it could be mounted... over where the LR compressor was? Like adjacent to the alternator, below where your air intake filter currently sits? Could you somehow keep the original LR compressor in its same general location, or possibly mount the Mercedes compressor over there? Is there any room to the left of the alternator, slightly above (10:00 position) or slightly below (7:00 position), or even directly to the left (9:00 position)?
Or perhaps could you move the Mercedes compressor out and up from it's original location, so that if sits just above the steering box, and to the right of the power steering pump.
Of course you'd have to custom fab brackets, but I'm wondering if there is even enough space to fit it in there?
Posted: Sat Sep 14, 2013 8:46 pm
by kentworks
Franco.... an update please. Was it worth it in the end? Does it drive well? Is the power of the OM617 matched well to the weight of the truck?
Posted: Mon Sep 16, 2013 9:26 am
by franko
Hey, yeah sure you could mount the AC on there just fine lots of room. We didn't bother with it,don't really need it up here.
And yes drives great power is not bad for what it is. Could use a rebuilt torque converter to get a better power band.
But so far its not to shabby.
I'm selling it as we speak ,just don't have time to tinker on it anymore with the new born and all.
