OK, what engine and gearbox??
Can you turn the engine over with the gearbox in gear and the clutch pedal depressed? Is the starter hooked up? There will always be a little drag.
Bleeding clutch
JD
Clutching at straws
300Tdi & R380
Clutch flat out isn't disengaging. Either push rod travel or clutch. Can't tell which. Have adjusted pedal travel and pedal feels very positive. So it's out with the engine again.
One day this project will end.
JD
JD
