Page 2 of 4
Re: Rebuilding Duffy
Posted: Fri Oct 08, 2021 8:16 pm
Ha, you did a nice job on the article. Anyone who has done LR U-joints will know exactly what you went through!
I've done a lot of U-joints over the years and can normally change mine out fairly quickly with a big vice and a big hammer, but its never any fun.
Keep up the good work
-Andy
Posted: Sun Oct 10, 2021 3:14 pm
by oldgravy
I rounded over two impact sockets trying to shift the cups out using a 3lb hammer. 😔
Posted: Wed Nov 24, 2021 2:00 pm
by oldgravy
Some more work completed!
I talk about paint, a subject I'm still learning about. The little, invisible painting / coating jobs never get any press. No one seems to write about them! Maybe it's because they're not really seen on a completed project?
By the way, I am concerned that people without Google accounts can't see my site hosted there -- if you click the link and don't get taken straight to the posting, then let me know?
Posted: Tue Nov 30, 2021 12:28 pm
by oldgravy
And
another post! This may be my last revisit of the rear diff. Maybe.
Posted: Wed Apr 13, 2022 1:54 pm
by oldgravy
I have an update. It's been a while! Got covid (did poorly), built a shed (built poorly) and bought a land rover frame which
arrived just this morning. Now I feel poorly.
I thought I would write about the process for those considering ordering a frame on their own from the UK.
Yes, I detailed my costs in the post. The end result might be a bit eye-popping.
Posted: Thu Apr 14, 2022 9:13 am
by oldgravy
Oh, I have one more update. I had to pay a further $18 to the Surrey Waste Transfer station to dispose of the pallet wood. Guys, don't just dump your garbage in the forest, somewhere...
Actually, eagle-eyed viewers might not a problem with the chassis I received. I ordered a LHD chassis with the P38 power steering mount option and Richards welded it to the wrong side. :( Discouraging.
Posted: Fri Apr 22, 2022 4:21 pm
by oldgravy
Quick update. I have managed to get the frame into the garage and promptly buried it under a mountain of stuff that's waiting for a more permanent home. :/
I reached out to Richards about the brackets being on the wrong side of the frame. To their credit, they have offered me a partial refund and they're sending over the parts to attach to the correct side. As with the ordering process, their customer service has been good. Truthfully there's not a lot anyone can do; it's not as if they can send me a replacement.
I'm not actually sure what I'll end up doing in the end. I wanted to have the option of adding power steering; figured if I was going to be ordering a new chassis, I may as well get the bracket added for what was (comparatively) little cost. Now I'm not so sure. I'm very reluctant to pay someone to grind off the galv and weld a bracket on to bare metal. The whole point was to have a rock-solid base from which to build upon...
Posted: Sat Apr 23, 2022 9:30 am
by bsa_m21
Sorry to hear of these issues.
I wouldn’t worry too much re longevity after welding on the pwr steering bracket to the LH side. 40 to 50 years from now, when the rust starts to get serious, you likely will be too old (if you are even still around - I won’t be) to get it repaired. 🤫😂😳
FYI - Industrial galvanizing paint these days is almost, but not quite, as good as the dipping process. I was told that you can heat the area to paint with a torch before painting then paint while still hot. This will flash bond the zinc paint to the metal. I’m going to try it one of these days to see if it really does make a difference.
Posted: Sat Apr 23, 2022 9:03 pm
by oldgravy
There is no chance I will be around in 40 years, Martin! 😂
Posted: Tue Jun 28, 2022 3:47 pm
by oldgravy
Two new posts!
One on
unpacking the chassis; and
Another on
more axle bull-crap!
Posted: Tue Jun 28, 2022 5:26 pm
by bsa_m21
Sweet! Glad to see you are making progress. :blob7:
Posted: Mon Jul 18, 2022 2:15 pm
by oldgravy
I have started to
paint things!
Posted: Wed Aug 17, 2022 10:19 am
by oldgravy
Okay okay okay, I need to make a decision on what I should do with the chassis before I start bolting stuff to it.
Should I:
i. Topcoat with POR15 DTM chassis black after scotchbriting + degreasing; or
ii. Just leave it bare galv?
The loose plan is to keep the original yellow colour...
Posted: Sun Oct 23, 2022 8:36 pm
by oldgravy
Man, is this job ever a pain.
Posted: Mon Oct 24, 2022 8:11 am
by John
Much harder to do on the vehicle when you have the hub to deal with.
Posted: Fri Oct 28, 2022 8:48 pm
by oldgravy
This is... frustrating. There is 6-8" at least between the shock and the mount with the weight of the chassis (and me) on the springs.
Posted: Fri Oct 28, 2022 10:36 pm
by mepham55
I would wait on the shocks until you’ve got the truck on its wheels and the rear body on. I’d guess you will need at least 300-400lbs on there to make new paras settle down enough to fit the shocks.
Posted: Sat Oct 29, 2022 8:37 am
by bsa_m21
mepham55 wrote: Fri Oct 28, 2022 10:36 pm
And don’t forget the check straps, else you may break one of those pretty shocks on full articulation. :bounce:
Posted: Thu Nov 03, 2022 5:28 pm
by oldgravy
Thanks, gents. I do have the rebound straps but they won't go 'round the axle as it is. I'm going to have to fix the brake pipe shields as those are actually supposed to be inboard.
I did
get up to some stuff over the summer, though!
Posted: Mon Dec 19, 2022 2:58 pm
by oldgravy
New post on starting the
front axle, with a diff from Ashcrofts!
Posted: Mon Dec 19, 2022 3:02 pm
by oldgravy
I also tried a test fit of the defender 200tdi on the chassis. The most immediate problem seemed to be the power steering pump, which interfered with the bump stop mounts.
I think the right side motor mount can be fabricated fairly easily. I've heard that the high pressure fuel pump gets in the way but... maybe not?
Posted: Tue Jan 10, 2023 8:23 pm
by oldgravy
Work continues on gearbox stuff. It's pretty dirty.
Posted: Wed Jan 11, 2023 4:58 pm
by oldgravy
And two new blog posts are up from back in November:
Some work I did to
reuse some old parts
and
Stripping down the front propshaft
Posted: Thu Jan 12, 2023 8:25 pm
by oldgravy
Getting caught up with posts. On to the gearbox:
Starting to take a look at the gearbox with
an overview of what we have and removing some small parts as per the Haynes manual and green bible.
Then on to
some basic cleaning, where I tried using oven cleaner. TL:DR; it works!
Posted: Fri Jan 13, 2023 2:06 pm
by StuartC
We can commiserate together......
:s3green:
I will have to endure the same process that you are now doing.
