Series 1 parts
Maggy57
- Apprentice
Re: Series 1 parts
Hi I’m looking for a transfer case and that 109 frame if is any good Chris location?
Maggy57
- Apprentice
Re: Series 1 parts
also looking for a firewall
Tony4921
Re: Series 1 parts
I have 2 spare transfer cases.
Maggy57
- Apprentice
Re: Series 1 parts
Great how was that 109 frame and fire wall chris 604 932 0755
Hamberger
- Newbie
Re: Series 1 parts
Do you still have?Hamberger wrote: Tue Feb 25, 2020 7:47 am Coming to the Island late April/May. Would like to get Early Series 1 rear axle shaft set.
Hamberger
- Newbie
Re: Series 1 parts
Still hoping for Early Series 1 Semi-Floating axle shafts.
regor
- Junior Craftsman
Re: Series 1 parts
Hi do you have any carb parts "23 pbi" in particular a "50" economy jet. Cheers
Quesnel44
- Grease Monkey
Re: Series 1 parts
Hi tony any of your series 1 stuff left ,had a work shop fire burned up my 1957, 88,...engine ,tub, doors, front fenders, instrument panel and floor panels , got most every thing else,cheers john.
Tony4921
Re: Series 1 parts
Hi, yes I still have lots of S1 parts left.
Quesnel44
- Grease Monkey
Re: Series 1 parts
Ok tony so give me a call sometime
2502495358 and we can hash it around ,I'm in the quesnel area cheers john,or [email protected]
Falling
- Rookie
Re: Series 1 parts
Hey, any chance there is a bonnet and a left door?
Tony4921
Re: Series 1 parts
Hi Falling, I have them both
StuartL
Re: Series 1 parts
Hi Toni,
I am looking for both doors for a 1952 80", don't need the tops just the bottoms hopefully with hinge and door handle.
Fingers crossed....
Fingers crossed....
Tony4921
Re: Series 1 parts
StuartL. mine are 55,56 &57's. Not sure if they are the same as a 52, but I have doors.
InterMechanico
Re: Series 1 parts
Any chance theres an oil bath air cleaner available?
Thank you!
Thank you!
mel rover
- Half Shaft
Re: Series 1 parts
Well I was hoping to find a 107 fraim body parts have lot of part to start the build need a frame to fix for the truck
Thanks Rob
Thanks Rob
cdr.bond
- Beyond Recovery
Re: Series 1 parts
Instrument panel together with clustered gauges, warning lights, ignition switch by chance?
JerryH
- Grease Monkey
Re: Series 1 parts
What shape is the roof with the top side glass? It’s on an 86” ?
Tony4921
Re: Series 1 parts
The roof is ok
Bucky1
- Rookie
Re: Series 1 parts
Hi Tony. Would you have M/C for brakes ,ignition switch and the the light knob. Thanks
SouthbankShawn
- Apprentice
Re: Series 1 parts
Hello - I’d be interested in a wing/guard/fender for the passenger side of a 57 109. Doesn’t need to be anywhere near perfect, that way it will match the rest of my truck!
Tony4921
Re: Series 1 parts
SouthbankShawn. Hi, yes I have far from perfect wings.
SouthbankShawn
- Apprentice
Re: Series 1 parts
Hi Tony, I sent you a Messenger enquiry, thinking about the 109 wings.
