Hello All,
I was wondering if there was anyone out there willing to make a duplicate set of brake lines for a Series 3 dual circuit set up. I am of course happy to pay, and before you ask, I do not want to do it myself. Please let m know if you can help.
JP
Brake Lines
jpclinging
- Little Wheel
Re: Brake Lines
Ok, change of plans. Does anyone have set of brake lines that I could dupl
icate? They would need to be off the truck...
island dormy
- Drag Link
Re: Brake Lines
Hi Jp
I think you may just want to go with buying a kit it they are cheap and come with everything you will need including little clamps to hold the line to the frame.
Yes it comes coiled up but the lines straighten out very nicely and are approximately the correct lengths.
If you check out the Land rover series 2 club site they have great info and will probably have a diagram of where the brake lines ran. Just remember they are not all exactly the same it kind of depended on which assembly line worker on the factory floor installed them.
* Be prepared to deal with leaks both with a kit or if you make them you self they always seem to need retightening.
Good luck Victor
Good luck Victor
