series 2a or 3 wanted *FOUND*
Forum rules
thegoose1
#1 Post by thegoose1 » Fri Oct 04, 2019 4:26 pm
looking for new project. had a 62 10 years ago . want another one pretty bad.
-Andrew in victoria bc
thanks all found something
Tony4921
Re: series 2a or 3 wanted
#2 Post by Tony4921 » Fri Oct 04, 2019 5:22 pm
I have a 67 2A, 88in. It runs and drives good, rebuilt 2 1/4 in it, parabolic front & rear springs, roof rack & ladder. I have removed all the paint, so there is absolutely no filler in it, some bumps and scrapes (character) I just dont have the time to use it and too many projects.
(113.76 KiB) Downloaded 613 times
British Bigfoot
Grease Monkey
#3 Post by British Bigfoot » Sun Oct 06, 2019 3:28 pm
what model are you looking for?
harv
Maxi Drive
#4 Post by harv » Tue Oct 15, 2019 8:13 am
I have 1963 88" 2A shell (body on frame, on springs and axle housings on wheels, you can roll it). I always thought I'd do another project with it, but I've had it 25 years and know realize I won't.The frame is quite good, except the rear cross member is rusty (might be salvageable) and there is a weld repair on the left front area. The bulkhead is virtually rust free. The body panels are all there, quite free of corrosion, but has its share of trail rash. If you're interested, I can try to figure out how to post some photos. Being that I have the registration for it, I think it's worth $1000. If anyone thinks that's out of line please let me know.
thegoose1
#5 Post by thegoose1 » Tue Oct 15, 2019 10:43 am
hmm perhaps. no motor / trans running gear? what kind of top etc?
harv
Maxi Drive
#6 Post by harv » Tue Oct 15, 2019 12:06 pm
Mechanically it's quite poor. Gearbox is in pieces, transfer case/front output are intact, but not installed, both diffs have broken pieces. I have a good motor (2.25 petrol) that could go with it, though I sort of want to keep it as it's the original for the 2A I drive. Top is the standard aluminum passenger type, with the LH window missing.
m_kenton
Wet and Wild
#7 Post by m_kenton » Tue Oct 15, 2019 6:52 pm
Hi
I am interested if the other party passes on it. Send me a phone # so we can talk.
Marc
mel rover
Half Shaft
#8 Post by mel rover » Tue Oct 15, 2019 7:55 pm
-Well I may have what you are looking for, I have a five door it comes with a 200 tdi and a Lt77 with a 230 transfer case. It has front disk brakes, parabolic springs and good tires.The body is in good shape as well as the frame. The rover has a new Salisbury rear end, and new shocks. I am open to offers. If you want more info give me a call. 250-498-0157 this is my house number, so if you don't catch me please leave a message.
Thanks Rob
harv
Maxi Drive
#9 Post by harv » Tue Oct 15, 2019 8:02 pm
My home phone is 250-765-6218.
thegoose1
#10 Post by thegoose1 » Sun Oct 20, 2019 8:23 pm
found somethings thanks all.
robert m
Muddy Tyres
#11 Post by robert m » Thu Jan 16, 2020 11:25 pm
Tony4921 wrote: Fri Oct 04, 2019 5:22 pm I have a 67 2A, 88in. It runs and drives good, rebuilt 2 1/4 in it, parabolic front & rear springs, roof rack & ladder. I have removed all the paint, so there is absolutely no filler in it, some bumps and scrapes (character) I just dont have the time to use it and too many projects.
Hi Tony
I don’t suppose you still have this..?
If so, how much would you take?
Robert
(604)219-5835
Tony4921
Re: series 2a or 3 wanted *FOUND*
#12 Post by Tony4921 » Fri Jan 17, 2020 4:31 pm
Sorry, long gone
