Good shop/mobile mechanic in vic?
A Forum for discussion between Rover enthusiasts on Vancouver Island
RamblerRob
Green Laner
#1 Post by RamblerRob » Fri Mar 08, 2019 9:22 am
Hey guys,
I'm getting into a part of my project that may be more technical than my google educated wrenching skills are up for.
Any recommendations on good shops or mobile mechanics in the area to finish up an engine swap?
Tony4921
Re: Good shop/mobile mechanic in vic?
#2 Post by Tony4921 » Fri Mar 08, 2019 6:27 pm
What are you up to? Its a Landy, can't be too hard.
RamblerRob
Green Laner
#3 Post by RamblerRob » Sat Mar 09, 2019 7:57 am
It's not so much the Landy bits, it's the engine swap and wiring
Everything is bolted in place, but I can't find much good info on getting the chev 4.3 {2006) set up and running
Tony4921
#4 Post by Tony4921 » Sat Mar 09, 2019 6:09 pm
Are you using the GM fuel injection, or gone to a carb?
RamblerRob
Green Laner
#5 Post by RamblerRob » Sat Mar 09, 2019 7:48 pm
Whole gm set up. I have all the wiring and electronics from the truck.
landcrabmechanic
Hot Manifold
#6 Post by landcrabmechanic » Sun Mar 10, 2019 9:03 pm
Rob,
The ecm for the 4.3 needs a 12V switched power source as well as a 12V hot power source (direct from battery).
I am not sure which pins they are to the ecm. Do you have a year for the engine as well as which GM is came out of? do you have the GM wiring harness?
I might have some info for you when I come to Victoria first week of spring break.
Scott in Vancouver
Landcrab Mobile Mechanical
Thanks for the sunroof
