300Tdi 110CSW Alternator
Troll Hunter
Know it all
#1 Post by Troll Hunter » Mon Oct 23, 2017 11:35 pm
This is my first post here, so I am a very Newbie, and I'm seeking local knowledge. I want to replace my 65amp alternator with a higher output unit, preferably 100+amp. Can anyone please recommend a readily available new/used unit as fitted to vehicles in north America? I don't want to pay for trans-Atlantic shipping and import duty by sourcing one in UK.
Many thanks, in advance, for any suggestions and recommendations made.
Mike
Specialist
Re: 300Tdi 110CSW Alternator
#2 Post by red90 » Tue Oct 24, 2017 6:22 am
There is no local one that is the same mount. You can buy from a local Rover parts supplier though if you want.
Master Cylinder
#3 Post by swamijake » Tue Oct 24, 2017 9:16 am
I wouldn't worry about ordering overseas. Here is the link to the post about all the places:
viewtopic.php?f=5&t=9313
The trick is try and get a shipping service that uses Canada Post on this end, ie Royal Mail. Canada Post doesn't jab you on the duty feed. Fedex and UPS are absolutely brutal for extra brokerage fees.
Or just call Jeremy and he'll get you one. The alternator you probably want is a disco 1 300tdi. I believe its a 100 amp unit.
Specialist
#4 Post by red90 » Tue Oct 24, 2017 12:56 pm
swamijake wrote:Fedex and UPS are absolutely brutal for extra brokerage fees.
Fedex brokerage fee is $10. It is zero if you have an account and have the import fees charged to it. You can get an account online in a minute. It costs nothing.
There are no duties on parts for vehicles over 25 years old. Have them note this on the invoice. You want tariff code 9966.00.00
Locally is simpler and more convenient, but it will normally be cheaper importing. The local guy has to make money and he is paying the shipping and import fees.
User avatar
withabix
Winch that stole Christmas
#5 Post by withabix » Thu Oct 26, 2017 1:52 pm
I found this web page that might help...
http://www.shearpin.org/pages/tdialternator.html
Seem to be about $100USD
User avatar
Cylinder bore
#6 Post by bsa_m21 » Thu Oct 26, 2017 4:04 pm
The MAHLE LETRIKA alternator p/n 11.203.405 cross references to:
DELCO REMY:
DRA3289
FORD NEW HOLLAND:
82857207, 83961474, E3NN10B376AA, E3NN10B376AB, E3NN10B376AC, E3NN10B376AD, F1NN10B376AA
LUCAS:
LRA00109, LRA00122, LRA00132, LRA00530
MAGNETI MARELLI:
63324256
MAHLE LETRIKA (ISKRA):
IA0505, 11201505, AAK1345, MG207, 11201495, AAK1341
So your local best bet might be to find a Ford New Holland tractor dealer for a 100amp alt.
https://www.agkits.com/ford-new-holland ... fKA13ZlDCM
And lots on eBay: https://www.ebay.com/sch/i.html?_nkw=la ... alternator
Martin
Series/Disco Coiler Hybrid (build in progress)
'52 S1 - Runcle
'96 Discovery 1 - Hothead
Specialist
#7 Post by red90 » Thu Oct 26, 2017 5:12 pm
A lot of the part numbers above are for the 45 Amp, pre 300TDI left hand adjuster style alternators. They are not what is desired here. The Ford crossovers are for the 45 amp and 65 Amp units that fit 200TDI and earlier Defenders and Series.
The 100 Amp unit used on the 300TDI is different. Buy a proper OEM one. It should be labelled as a Marelli or Denso. Do not get an unbranded one. It will fail. Make sure you upgrade the power wiring.
https://www.lrdirect.com/AMR4248-Alternator-300Tdi-Ds/
Troll Hunter
Know it all
#8 Post by Troll Hunter » Wed Dec 06, 2017 10:04 pm
Many thanks for the input, guys. I was hoping that a suitable unit common in north America would turn up, but it looks that if I'm to upgrade I need to get a Denso or Marelli unit. Guess I'll have to wait a while, since it isn't an urgent requirement.
Mike
