Transfer case modification
reefworld1
#1 Post by reefworld1 » Sat Nov 12, 2005 11:54 am
Hi, Does anyone have any info regarding the high ratio transfer case mod. This is suppose to overdrive only your high range?
Greasy Fingers
#2 Post by Rob » Sat Nov 12, 2005 12:52 pm
Good day:
You might find this site of interest:
http://users.mrbean.net.au/~rover/high. ... l%20Ratios
it has info regarding high speed transfer case conversion for series rovers
Regards, Rob
83 88
88 RRC
reefworld1
transfer case mod.
#3 Post by reefworld1 » Sat Nov 12, 2005 3:24 pm
I checked out this site but it doesn't give enough tech. info to perform the machining.
#4 Post by DaveB » Sat Nov 12, 2005 6:00 pm
Ashcroft transmission has a complete kit:
http://www.ashcroft-transmissions.co.uk/part_37.html
Might be your cheapest in the long run.
Green Giant
high ratio
#5 Post by Green Giant » Sun Nov 13, 2005 8:44 am
I have a high ratio gears in my 88", and yes it only affects high range.
